springs settled after alignment!!!!!
Old Sep 26, 2005
fuledya's Avatar
Super Member
fuledya is an unknown quantity at this point
Okay, so I waited 3 days for my Tein SS's to settle before getting an alignment, and it seems my rears have dropped about a 1/4 of an inch.
Will it be okay to raise the back that amount w/o throwing off my settings? Im sure camber would be just fine, just not sure how rear toe is effected by raising or lowering the car?
I just want to raise it to the level it was when I got it aligned, will I be okay???
Old Sep 26, 2005
CLeeNx04CiVic's Avatar
CLeeNx04CiVic has a little shameless behaviour in the past
u should of waited atleast a week or so before getting that alignment for it to reall get settled in...but i doubt it would of affected it that much though
Old Sep 26, 2005
streetglower's Avatar
I think waiting anytime to get an alignment is none sense. I know alot of you may disagree, but I believe after you put on springs, shocks, or coilovers, you can go right afterwards and get an algnment and you will be fine. I dont think the amount that they will settle will have that big of effect on the alignment settings. I have always done my alignments after I have done my suspension and have never ran into any problems.
Now I think you will be fine raising it up a 1/4 of an inch without affecting your settings. If you were going to raise it up 2 inches or so, it would cause problems, but not with 1/4 inch.
Old Sep 26, 2005
fuledya's Avatar
Super Member
anyone else? my main concern is would toe be effected?
Old Sep 26, 2005
es2k2's Avatar
Proud to be a civic owner
i did the alignment right after i installed the coilover because the rear wheels was tilting sideways...
Old Sep 27, 2005
fuledya's Avatar
Super Member
anyone else?
Old Sep 28, 2005
skipbarber's Avatar
my tein SS dropped about an 1/8th inch the week after i installed them, so i re-adjusted them. within the last 5 months they have gone down about a 1/4 inch. I have to re-adjust it soon because the rear is now sitting a hair lower than the front, when initially i had them a bit higher than the front. Tons of people that I know have coilovers encounter similar issues. It's whatever, a few fractions of an inch wont throw off your alignment that much, nothing to be worried about IMO.
Old Sep 28, 2005
robbclark1's Avatar
Retired suspension supermod.
I am assuming the rears settled more? The rears will just camber in a bit. Toe kills tires, but that shouldn't change much when the rear drops. Toe kinda changes as you hit pot holes and ****. You can double check with boilermaker though.
SG, it is important to wait to get an alignment. Even have jacking up the car, the rear may take a few drives or hours to fully settle.
skeener51
Oct 1, 2015 05:56 PM
Tedverseti
Sep 29, 2015 05:41 PM
Wariogamer
Sep 29, 2015 09:49 AM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
TheRiddicles
Sep 21, 2015 01:28 AM
