my TEIN basics go ra-ra-ra lol
Old Sep 19, 2005
Caucasian.Asian's Avatar
well, i just recently installed my tein basics. after about a week or two without any problems they are starting to make noise.
while decelerating and/or coming to a slow stop my front drivers side suspension slowly makes a sounds like ra-ra-ra-ra-raaa. and sometimes while making a slow right turn it does the same thing but a little bit different.
at first i thought it was my power slot slotted rotors maybe screwing up and and rubbing the brake pads incorrectly while braking, but now is does that even if i'm not hitting the brakes.
i'm worried because it seems to be increasing little by little and i don't want something to go wrong and end up stuck somewhere, or maybe even cause an accident.
i've had a very busy week so i haven't been able to take a look at it yet. so i'm asking anyone to give me advise on what to check/loosen/tighten or possibly what exactly is causing my problem, so when i do have time i can go straight to the problem area.
thanks guys!
Old Sep 19, 2005
robbclark1's Avatar
Retired suspension supermod.
make sure ALL the bolts are tight and make sure the springs are tight.
Old Sep 19, 2005
mr_fobster's Avatar
hahah damn simeon!!! that hell sucks ***! lets hope my ss-p's dotn do this.....lol
Old Sep 19, 2005
es2k2's Avatar
Proud to be a civic owner
i have the tein basic and i have noise coming from the front driver side.. the guy who installed it said can't find anything wrong with it... he said lubricant is going to help much.. but now i'm thinking maybe it's something with the front sway bar or endlink something like that??? i really have no idea and want a clear answer myself too... i'm kinda sick of the noise and i just crank the music out loud... :-(
Old Sep 19, 2005
Yoyoio's Avatar
Yoyoio is an unknown quantity at this point
no problem with my basic.
-make sure locks and all nuts/bolts are tight
-01 bearing?
-enought tension on spring, because i had my rear spring boot seat rubbing on the spring once, and it made some nasty sounds.
Old Sep 20, 2005
mrDFWmechanic's Avatar
maybe a missing washer or somethin ?
Old Sep 20, 2005
BiGDoG's Avatar
BiGDoG is on a distinguished road
U Might Need The 01 Bearings If Ur Car Is 02+
Old Sep 20, 2005
Da1lyDr1ver's Avatar
yup, you need '01 top mounts.
Old Sep 20, 2005
my car is a 2001..............
Old Nov 20, 2005
ashtonp's Avatar
ashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to beholdashtonp is a splendid one to behold
sorry to resurrect this but i am currently having the same problem, Caucasian.Asian, what did u end up doing?
Old Nov 20, 2005
es2k2's Avatar
do i need to order the bearing (part #465510) and/or the upper mount (part #465628)?
Old Nov 21, 2005
ashtonp's Avatar
u need the upper mount, u may need the bearing if yours is broken, you'll know you'll need the bearing if ur hammering away at the knuckles and little ball bearings are falling out from the top of the strut, as in my case
Old Nov 21, 2005
TheSmuggler's Avatar
I got a pair for sale lol
Old Nov 21, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
You need to make sure that index marks on the struts line up, it not, then your strats will make a noise.
Old Nov 21, 2005
es2k2's Avatar
but it's a coilover.. not a spring+shock combo
Old Nov 21, 2005
robbclark1's Avatar
thank you!
GolNat
Nov 27, 2018 03:32 PM
ricer_em2
May 11, 2016 08:09 PM
ttamrekab
Sep 28, 2015 01:22 AM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
