Front Drivers side 1/2" lower then Passenger side.
Old Sep 19, 2005
llatikcuf's Avatar
llatikcuf is an unknown quantity at this point
OK – as you may know from my previous post:
Driver side front strut failed ~6 months ago. I was ~2000 miles over
warranty. Wrote a letter to Honda USA, and they said they would cover
the failed strut, and only the failed strut. This was the second time the struts were replaced.
Went to the dealership for the service and offered to pay for the other
strut because I had heard you should have them replaced in pairs.
Dealership recommended I only replace the one strut because car only
had 38000 miles on it and "Driver weight stresses the driver side
strut, more than passenger side. Therefore driver side wears much
faster." They replaced only the one side. Slight pull to right in the
car, but I was told that will go away as the new strut wears.
Now, 4 months after the service, 5000 miles later, car still pulls and
just noticed car leans to the driver side about ½ inch. (35.5” from ground to top of wheel well on drivers side – 36” on passenger side) I figure this is the cause of the pull.
I just learned that Honda uses two different struts for the 02 Civics, is it possible that I now have one of each and they are different heights? Springs?
Car feels like I’m driving a plate of jello. I figure the passenger side is about to go, So, now I’m buying new struts – Probably Tokico Blues. This will fix my strut problem, but what about the ½” lean?
Any thoughts would be appreciated.
Thanks,
Nate
Old Sep 19, 2005
scarypunk's Avatar
scarypunk has a little shameless behaviour in the past
do u usually hit enter in the middle of sentences ?
Old Sep 19, 2005
robbclark1's Avatar
Retired suspension supermod.
Tokicos will help, but you will always have a lean. The drivers side is where you sit and the engine sits. It's nomral. Tokicos will help with your crappy struts blowing, so get a set.
Old Sep 19, 2005
llatikcuf's Avatar
Sorry, posted it to Usenet first -- it has a word wrap.
-nate
Old Sep 19, 2005
llatikcuf's Avatar
Do you usually abbreviate three letter words?
-n
Old Sep 20, 2005
llatikcuf's Avatar
What about the pull to the left, could this be caused by the left strut being newer than the right strut? Tokico's help this?
Thanks again,
Nate
Old Sep 20, 2005
robbclark1's Avatar
Thanks again,
Nate
Can't tell unless you put them and get a GOOD alignment.
Old Sep 20, 2005
wheamahm0n3yat's Avatar
wheamahm0n3yat is an unknown quantity at this point
sounds like you need an alignment.
Old Sep 20, 2005
robbclark1's Avatar
Tokico's are a great upgrade from stock shocks and will last longer, especially if you keep stock springs. I put tokico's on abstractprodj (http://www.7thgencivic.com/forums/sh...d.php?t=224727) car and he says they were better than his blown stockers, obviously! I highly recommend getting them sometime just because you are having so much trouble with the stock ones.
Old Sep 20, 2005
CuRiOuSfIsH's Avatar
Back From The Banned!
wasnt there a TSB back in........ 2002 or so about the driver's side tilting slightly?
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
crowtoo
May 11, 2015 06:50 PM
tattedlariat
Apr 12, 2015 07:55 PM
big20ugly
Nov 11, 2001 08:30 PM
mwwhonda
Nov 7, 2001 07:24 PM
