Anti-sway Bars should be Thicker 4 Front or Rear?
Old Sep 19, 2005
icetrap's Avatar
icetrap is an unknown quantity at this point
I am ordering Type R parts (22mm) Bars for my car.
I understand Progress is offering 28mm Anti-sway bars for the front. I am thinking of getting them too.
Since our cars are FF and meant to understeer, will a thicker anti-Sway front bar (example 28mm front, 22mm rear) cause our car to understeer more?
Ok this sounds stupid but if we want our car to be a more neutral setup, won't it be better if we have a thicker bar at the rear instead of the front? This should allow the understeer to be eliminated
Old Sep 19, 2005
robbclark1's Avatar
Retired suspension supermod.
It depends on how much understeer or oversteer you want. I think 28 front is too excessive. I have 25 front and 19 rear and I wish I had a larger rear bar. My friend has the progress 27mm front and the 22 rear and sometimes he can get his car to rotate. A 22mm rear bar with the stock 25.4mm front (not the 15.6 mm front( will probably feel nice, if you have the rest of your suspension set up properly.
Old Sep 19, 2005
icetrap's Avatar
Now the trouble is to find a Front thinner sway bar for my 22mm rear bar.
I running on the Type R springs springs and strut btw
Damn, why they don't aftermarket company make the front bar smaller... Any recommendation on brands dude?
Old Sep 19, 2005
robbclark1's Avatar
Eibach makes a 25mm front bar. You can get an OEM front 25mm bar (01-02) or if you want more oversteer you can get an OEM 15.6mm front bar (03+).
Old Sep 19, 2005
Redviking's Avatar
Redviking is on a distinguished road
You can also look for:
- 22.2mm front bar from a 2002 sedan
- if you don't have a EX, you can also look for the 23mm front RSX bar (before 2005)
Old Sep 23, 2005
boostaddict's Avatar
boostaddict is on a distinguished road
Ok, dont get all worked up here - but I am not even running a front sway bar. First thing I noticed was loss of initial turn in - the steering is not quite as precice, but man, midcorner and exit are ****. I am currently playing with spring rates/lengths/shock rebound and corner weighting to get my corner entry back.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
PimpBot5000
Nov 26, 2001 07:15 PM
andylao
Nov 9, 2001 07:36 PM
JeffSpeed21
Bolt-on Engine Performance
Nov 4, 2001 12:33 PM
