!!!!!!!!!!!!Need HELP ASAP!!!!!!!!!!!!!!
Old Sep 17, 2005
fuledya's Avatar
Super Member
fuledya is an unknown quantity at this point
okay, while installing my teins, I had to cut a few threads off my tie rod endlink, because it got burred up, don't worry, i still got enough threads for the cotterpin. But as I was cutting it with my dremel, the bolt got warm, and a little grease spit out, is this okay?
Im assuming it was because of the heat, but am I gonna run into problems? I need to get my car done, and the dealership won't be open tommorow, what should I do?
BTW, the boot is fine, no tears or anything.
Old Sep 17, 2005
BiGDoG's Avatar
BiGDoG is on a distinguished road
Ohhhhh Man Ur In Some Deep ****
Old Sep 17, 2005
streetglower's Avatar
what do you mean the bolt got warm and grease spit out? there is no grease in a bolt. Maybe I am not reading this right.
Old Sep 17, 2005
blouisgod's Avatar
Life Begins > 6800rpms
as long as the boot isnt cut or ripped to badly you should be ok. i think when i installed my b&gs some grease came out but i had not ripped the boot.
Old Sep 17, 2005
fuledya's Avatar
Super Member
i was cutting the bolt, at the end of the endlink. Grease spit out where the knuckle is, around the rubber boot. The boot is fine, im just wondering if i lost too much, and know there isn't enoug grease in there, and there is no way of adding more, there not repackable.
Old Sep 17, 2005
robbclark1's Avatar
Retired suspension supermod.
he heated the grease up too much and it got too liquidy and squirted out. If you feel you haven't lost too much then go for it. Just keep an eye on it.
Old Sep 17, 2005
fuledya's Avatar
Super Member
Rob, how much do you think is in there?
What should I look for?
Is there anyway to repack it with grease?
I may have lost an amount the size of a quarter.
I haven't got an alignment yet since installing my Teins, but I hate to replace the tie rod if it will be okay....
What do you think?
Old Sep 17, 2005
Da1lyDr1ver's Avatar
theres more than a quarter sized amount of grease in the boot. i ripped mine before so i know. if you're worried, then you can just replace the boot and not the entire tie rod. this is the only way you can "repack" the grease in the tie rod.
Old Sep 18, 2005
Vinh's Avatar
those dang boots cost $50 a piece
Old Sep 18, 2005
robbclark1's Avatar
boots do not cost $50 a piece. The whole end costs less than that.
Dailydriver is right. The only way to repack it is to replace the boot. Personally, I would rather replace the whole end because it is easier. I think you should be fine, but that is just my opinion.
Old Sep 18, 2005
03-Acura-1.7-EL's Avatar
03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light03-Acura-1.7-EL is a glorious beacon of light
Buy appropriare grease at auto parts store. Take tha boot off, insert neede dammount of trease into the boot and put it back togeter. Will work as before!
Old Sep 18, 2005
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
Thats not true. if you go through honda they tried to charge me 150 for the tie rod end.
Old Sep 18, 2005
thats because honda charges you retail price plus labor. And all hondas are different. The boots for the tie rod ends are almost $2.00 while each tie rod end is around $40. Look for yourself.
http://www.hondaautomotiveparts.com/...=P.S.+GEAR+BOX
Old Sep 18, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
If a little squeezed out and the boot is intact, then its fine. There's more than enough grease packed in there to keep the joint covered.
Old Sep 18, 2005
my boot i brought from the dealership cost $5. i did the labor myself. it was a pain in the *** tho.
Old Sep 18, 2005
Vantage's Avatar
Vantage should not be trusted
ya repacking sucks, ive played around with a few axels/tie rods on my old car, there is quite a bit in there so unless u had a small puddle u should be ok. if not, better safe than sorry and wait till u can take it to honda.
