Help in diagnosing problem...
Old Sep 2, 2005
rexroth's Avatar
rexroth is an unknown quantity at this point
I installed Koni yellow with H&R springs...Install was fine but while driving, a "loud thump" can be heard on my Rear-right suspension when going over a bump and specially during cornering left. It's annoying! Can't figure out whats wrong...One thread mentioned to cut the bump stop into half to give more room for the shock to move, but like what mentioned, the sound only comes in one side...I checked every components and I can't seem to find the problem...Please help...Thanks....
Old Sep 2, 2005
Sdcivic549's Avatar
Sdcivic549 is an unknown quantity at this point
First thing you need to do is cut down your bumpstops if you haven't already done so. The thumping noise is likely coming from your upper mount, check the order you assembled everything in the upper bushing assembly. If that's right then jack up the rear of the car, grab the shock and try to move it around, check for play in the assemblly.
Old Sep 2, 2005
Zzyzx's Avatar
Autocross Junky
ONly on Left turns? I know exactly what it is, and it has nothing to do with your konis....
Its your anti-roll bar, hitting yoru exaust and pushing it up in to the bottom of the chassis... use to happen to me all the time. To be sure check the exaust pipe near the anti-roll bar, see if there is any indication of contact with the anti-roll bar....
Old Sep 2, 2005
rexroth's Avatar
I checked the bushing order and everything was right, plus I cut the bumpstop in half, I will re-check if theres a play from the upper srtut mount and check the anti-roll bar and this weekend and will let you know...Thanks guys!
Old Sep 2, 2005
rexroth's Avatar
Hey guys, I checked if there's a play in the shock...there is a little bit play. I tried swtiching the shocks (RearLeft to <-->Rear Right) just to rule-out any upper strut mount damage,,,still the noise is present. Also, there is no indication of contact between the anti-roll bar and exhaust pipe...This is driving me insane! Help please....
rovafa2002
Sep 28, 2015 06:57 PM
rayaan_wasty
Sep 14, 2015 02:00 PM
Nicklaus2015
Sep 14, 2015 10:14 AM
CraigW
Aug 18, 2015 07:06 AM
f575gtc
Transmission
Jul 13, 2015 09:16 PM
