Neuspeed Race (Help Plz)
Old Sep 1, 2005
Midnight_racer's Avatar
Midnight_racer is an unknown quantity at this point
Well i recently just got done installing the neuspeed race spring and im having problems. Lets start with the problems.I installed the springs with the flat part down (if it is a problem). After the install i went for a test drive and it sounded like the springs wanted to come out of the strut after every lil hump on the road, thats right a hump not a bump. And now the tie rod bolt is stuck to the strut, try everything, and couldnt even make it budge so its stuck. So any replies on this would be much appreciated, Thanks in advance.
Old Sep 1, 2005
usafcushman's Avatar
7thGen's Loudest Civic...4,000 watts and climbing...
usafcushman is on a distinguished road
holy $hit man, that sucks much... i have Neuspeed Race springs on my '03 EX sedan, so maybe i can help you out... i'll check out my car and see if i can figure something out to help you... good luck in the mean time though, sounds like something's seriously jacked up...
Old Sep 2, 2005
the problem is still there someone please help.
Old Sep 2, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
IF the front springs are flat side down, they're upside down.
If the rear springs are flat side down they're upside down
The springs arent seated, hence the racket.
The "tie rod bolt" as you call it I assume to be the threaded end of the ball joint, and its supposed to be stuck in the strut, its tapered to jam in when you torque the nut down. Thats why you need a special tool to get it out.
The short unsugarcoated version: You ****ed up and you have to take it all apart and do it again. When you do it this time, index the struts (line up the arrow on the hat with the line on the mount and the line on the seat), and install everything right side up.
Better yet, take it somewhere where someone knows the right way and have them do it so its done right.
And while your at it, buy yourself a set of Konis, stock struts don't stand a chance.
Old Sep 2, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
front, text should be upside down, rear, text should be right side up. About the tie rod bolt, its seized from over tightening. Its happened to me as well. You can buy a new tie rod bolt from honda and a new end if you need. But you're going to need to break off that bolt.
Old Sep 2, 2005
dariusld's Avatar
dariusld is an unknown quantity at this point
On the front strut are those upper tab things supposed to be staight or bent? Some of mine were bent so I straitened them and it helped some of the noise mine were making go away. Sorry for the terminology.
Old Sep 2, 2005
dariusld's Avatar
My rear lettering is upside down. The spring wouldn't fit right the other way. Before you buy anything just try to be a little more persistant. I put something solid behind the strut arm and use a regular hammer and start wacking it good. Works every time for me. Whatever you do NEVER use one of those pickle forks to remove ball joints. You might as well buy a new ball joint even before you start with one of those.
Old Sep 2, 2005
Blahman240's Avatar
Originally Posted by dariusld
My rear lettering is upside down. The spring wouldn't fit right the other way. Before you buy anything just try to be a little more pesistant. I put something solid behind the strut arm and use a regular hammer and start wacking it good. Works every time for me. Whatever you do NEVER use one of those pickle forks to remove ball joints. You might as well buy a new ball joint even before you start with one of those.
hmm... then maybe its the other way around. WAIT YES IT IS. Front lettering right side up, and rear upside down.
Old Sep 2, 2005
Blahman240's Avatar
upper tab things?
Old Sep 2, 2005
dariusld's Avatar
Number 2, but the pict. doesn't show the tabs
upper tab things?
Old Sep 3, 2005
Blahman240's Avatar
I still don't know what you're talkin about.
Solo Flow
Oct 4, 2015 07:52 AM
Luluharp
Sep 27, 2015 11:56 AM
