OMG! I lost a bolt!
Old Aug 29, 2005
K20me's Avatar
OMG! I lost a bolt!
Hey guys/girls. Just wondering if anyone knows where (Home Depot or whatnot) I can get a new bolt/washer combination for my Progress Sway bar brackets. I came home today and I was missing a bolt, which resulted in the sway bar making noise when i'd go up inclines. If anyone knows let me know please! I will try to look for it in Progress' website for now. Thanks!
Old Aug 29, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
It would help if you told us which bolt you lost. If its metric, and bigger than 12mm don't plan on Home Depot having it. You're probably going to need a specialty fastener store, Honda or some place like Mcmaster carr. The bolts for the bushing brackets are 10mm I think.... they should have them.
Old Aug 29, 2005
K20me's Avatar
I thought it was either a 10mm or 12mm bolt, but I'm not using the OEM bolts because Progress had their own set of bolts that came with the Sway/Tie bar combo. Here's pictures though. Looks like a need a new bracket too because this one bent.
Old Aug 29, 2005
Vantage's Avatar
Vantage should not be trusted
once u install the bolt again, it will pull the bracket back into place. measure the length or the other and go to a yard and pick 1 up, if not go to honda and see if they have something similar.
Old Aug 29, 2005
cubanmike26's Avatar
If I were you, I'd remove the bar till you get the new bolt; might end up messing something else up...
Old Aug 30, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
Oh man... ::goes out to tighten his bolts::
Old Aug 30, 2005
Jeff's Avatar
Jeff is an unknown quantity at this point
Thats why i replaced mine with all grade 8 bolts and lock tighted them. There was a thread along time ago that gave you sizes on what to buy to replace the cheap bolts progress sent with there kits.
Old Aug 30, 2005
K20me's Avatar
You really think the bracket will bend back with a new bolt? Just wondering. Thanks!
Thanks for the replies. I don't exactly know where to get grade 8 bolts, so if anyone just please LMK. I won't be driving around my car for the next few days until I can get all this fixed. Luckily, I have another vehicle to drive.
Old Aug 30, 2005
Boilermaker1 mentioned it before, you can the get the bolts from Mcmaster.com, I just can't remember which size bolts you need though.
Regarding the bent bracket, a vise may help to put it back the way it was.
Old Aug 30, 2005
Vantage's Avatar
i think if you put the bolt through the bracket hole, and slowly snug it down, the bracket will unbend itself.
Old Aug 30, 2005
Jap-Euro Fusion
If you still have the OEM bolt, put it back in, if nothing else, it'll hold it. If you have a heat gun, take the bracket off and heat it up and bend it back straighter. I'd be worried about it cracking if it was cold and you bent it back.
You shouldn't need grade 8 hardware, and you can't buy grade 8 metric hardware.
Its on a different scale, and its measured differently. Metric grade 8.8 is standard issue.
Old Aug 30, 2005
K20me's Avatar
Thanks for all the advice guys. I went with a temporary fix and rebent the bracket to fit perfectly onto the bushing again. I did it by using a vice grip and hammer. There was no cracking, and to be honest, the bracket material seems to be very pliable (sp?). I am temporarily using an OEM bracket screw for the missing bolt, and will be heading down to a place later where I can buy stronger screws. The bracket looks normal once again, and I just wanted to thank you guys for your input.
rovafa2002
Sep 28, 2015 06:57 PM
2002ExCivic
22
Sep 28, 2015 08:29 AM
Yang559
Transmission
Sep 21, 2015 01:41 PM
Jrosa
Sep 14, 2015 08:24 PM
Bman2212
Sep 2, 2015 11:49 AM
