Neuspeed Front Lower X-Brace or Tanabe Sustec Under Brace
#31
Originally Posted by Dr. Design
Actually the Double X-Brace is constructed out of 304 1" tubing stainless steel and is tig welded. The Nuespeed x-brace uses mild steel. When you compare the material characteristics, the tensile strength of Stainless Steel is far superior to mild steel! Also by design, the double x-brace design is structurally much more solid than the single brace that is currently mentioned. Besides it will out perform both bars hands down!!
Dr. D
Dr. D
#32
Originally Posted by tamazoid
I'm sure the D3 Double X-Brace is strong, but I was reading the post on ClubRSX and they seems to take a long time to install it... I took like half an hour installing my Nuespeed X-Brace with no problems.
But some people enlarged the hole in the bar to make it fit or I even saw someone who welded the bar to the chassis !
#33
1 Post
Originally Posted by Redviking
Yeah, I read the same thing. The 2 added fixing point (compared to Neuspeed) seems to be a hell to bolt on. If your chassis is not 100% at it should be, you have a little fitment issue!
COME ON, INSTALLATION IS HALF THE FUN!!! GET A BUNCH OF YOUR FRIENDS OVER WITH STUFF TO INSTALL, AND HAVE FUN!
#34
The install is actually much easy than people lead to believe. I have installed one in about 25 minutes. Even quicker with airtools!! Its just about how good you are mechanically speaking. Bottom line is they always fit and are always installed!! A lot of people tighten bolts before all the bolts are started.
Dr. D
Dr. D
#35
#36
Super Member
Rep Power: 0 I was the 1st EM2 w/ this brace.. yes it is a bitch to install.. read more in here http://www.7thgencivic.com/forums/sh...d.php?t=229349 but the install was well worth it...
heres my car w/ side shots of the brace installed
#38
Super Member
Rep Power: 0 yep.. 2" at the lowest point of the brace and im riding on stechs (1.5inch drop) but if u angle ur car on a high speedbump you should be good.. i only have a pronblem w/ 1bump but if angled i go smooth over it and the other bumps is minor kine
#42
Super Member
i ordered the neuspeed x-brace last week for $146 SHIPPED.
i should be getting it today...
old97civic
07-09-2015 12:19 PM
beachglass
05-22-2015 09:59 PM
