TEIN Flex with EDFC On the Way!
Old Aug 11, 2005
DrScottie's Avatar
DrScottie is an unknown quantity at this point
Talking TEIN Flex with EDFC On the Way!
Hey guyz,
I just ordered my TEIN Flex's with the EDFC controller for my '01 Vic.
I have read the other posts with folks with the Flex setup, but the only other member I've seen with this setup is Rijowysock.
I'll post some pics of the install if necessary (electronics hookups and location of EDFC).
Oh ya, I ordered the SPC Pro camber adjustment kit as well, in case anyone was wondering. (That's the one that comes with the lower rear control arms.)
I have read it requires a bit of hood modification, But I can handle that. Rijowysock - Did you have to modify your hood to fit the Flex you got?
Peace
Old Aug 11, 2005
Yoyoio's Avatar
Yoyoio is an unknown quantity at this point
where did you order and how much?
Old Aug 11, 2005
robbclark1's Avatar
Retired suspension supermod.
Originally Posted by DrScottie
Hey guyz,
Peace
The rear arms won't do much but look pretty. You really don't need the front cam bolts, but you can put them in if you want. YOu will have to cut the skeleton of your hood to make the EDFC to fit.
Old Aug 12, 2005
DrScottie's Avatar
Thanks for all the info.
I got the entire setup (not including camber kit) for about $1950.00 from www.hpautoworks.com ($1550 Dampers - $300 EDFC) plus tax/shipping.
SPC Kit was $200.00 from another place.
I will probably not install EDFC right away and allow dampers to settle first. But I will take pics of the install and before/after shots.
Old Aug 12, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
Wow... thats a whole lot of unnecessary gizmos and garbage that you didn't need.
You do realize that once you get the dampers in the right place, you're never going to touch the EDFC box again right? And its really not hard to just turn the **** by hand?
Honestly, I'd return the EDFC and the LCAs if you can. There's really no need for either.
Old Aug 12, 2005
tamazoid's Avatar
tamazoid is an unknown quantity at this point
but you can have 3 presets on the EDFC...
Old Aug 13, 2005
Jap-Euro Fusion
I can mark 3 spots on the shock tower and go between them in 3 seconds OR, I can learn to count to 16 and just go 1, 2, 3, etc... to where I want them. Whats your point?
Not to mention it isn't legal for any sanctioned racing. So they're really just selling it as a gimmick. It has no real fuction that you can't do by hand.
I haven't touched the ***** on my shocks in 4 months, track time, street, autocross, whatever. Once you get them set right for the spring rates, you're never going to use it again. Its not like you're going to have a highway mode and a speed bump mode or something.
Old Aug 14, 2005
dru106's Avatar
ThE CoRRupToR
So very true!!! Thats waaay too much $$ for suspension mod for a civic you dont need..........
Old Aug 14, 2005
EM2typeflex's Avatar
EM2typeflex is an unknown quantity at this point
^^I'm feelin you on too much money for the suspension, but if the car is gonna be in shows, why not
Old Aug 16, 2005
dru106's Avatar
ThE CoRRupToR
Haha!! Then it will serve no purpose if its just for show only lol........
Old Aug 18, 2005
tamazoid's Avatar
Well you can show off the control modules when you pop the hood open...
Old Aug 18, 2005
dru106 haven't you ever heard of a street/show car?
Old Aug 19, 2005
dru106's Avatar
ThE CoRRupToR
Errrr, im not gonna get into this......
Old Aug 19, 2005
usafstud's Avatar
Return the EDFC to pay for track/autoX days to learn how to drive, but its your $$
Old Aug 19, 2005
Jap-Euro Fusion
4 boxes from animal crackers spraypainted green would do the same thing. Plus they have the little stringy thing that you can pass off as the wire.
Old Aug 19, 2005
usafstud's Avatar
U so funny
Old Aug 19, 2005
I swear I dont mean to offend anyone, but I see where your coming from since you autox guys wouldnt need anything like that; on the contrary, someone who's actually built their civic for the 1320 would make definite use out of that. WHATEVER YOU SAY DRU106 YOU THE MAN
Old Aug 19, 2005
Jap-Euro Fusion
Umm no offense, but thats the dumbest thing I've ever heard. I'm pretty damn sure when you have to turn... suspension is life. You can use fixed rate dampers to run 1/4s..... the track is the same every time. Point the car.
Want to run 1/4s.... throw everything you got under the hood, then make sure you have just enough to hold the car down. Suspension doesn't knock off more than the .1 you gain from having a properly tuned one keep you on the ground out of the box. After that, its along for the ride.
EDFC is TOTALLY USELESS. Its like the tein hydraulic hood prop. A stick works, but its not green. Its like carbon fiber gas caps, neon lights and fart tips, but with a big tag. High end rice if you will. There is absolutely no functional point to it beyond something to just have because you have an excess of money. There's far too many ways to adjust the way a car handles, damper adjustment is probably the last one you really want to **** around with. Its a black art. Its all guessing. You have far more luck adjusting the handling with alignment, tire pressures and sway bars than you ever will with shock adjustments... all they're there for is the last extra ounce when you've done everything else.
Old Aug 19, 2005
you know now that i think of it i shouldn've spoken on behalf of autox people, the 1320 example was pretty dumb, and i can see where you're putting edfc in the rice category or something like that. I guess i was thinking of a quick 1/4 street race where you would want to change damper setting from street to race, those 3 presets on the edfc.
Old Aug 20, 2005
tamazoid's Avatar
There's no point arguing with these guys... They have their minds set on what they think, and there's no way to change it...
I say the EDFC is good because you can test and tune it real-time, rather than getting out of the car every time to change it. And then save it to one of the three presets...
Old Aug 20, 2005
im not arguing with this VV trick, nor would i try, my car would smokem in the 1/4 where it counts to me. After he reads what i post, talk is cheap, a comparison of our civic's would deem me the victor effortlessly
Old Aug 20, 2005
Jap-Euro Fusion
im not arguing with these trix, nor would i try, my car would smokem in the 1/4 where it counts to me. After they read what i post, talk is cheap, a comparison of our civic's would deem me the victor effortlessly
Your CAR would smoke us. Whoopdy do. WE would smoke you. If I had all the money in the world, sure... why not 4 turbos, 3 superchargers and lots of NAWZZZZZ. Its just much funnier to blow by people like yourself who think they're the **** because they have "fast cars". People who road race DRIVE THE CAR. Anyone can drive in a straight line and win with enough horsepower, it takes no skill at all. 90% of actually driving is the guy at the wheel.
Old Aug 20, 2005
^^Oh I see where your going with this. Did you come out in stomp? Put a little bit of this right there on your car and bam. Just had to, this thread went way off topic with boilermaker here trying to rag on me, must really be insecure on the size of his manhood.. Anyway your right, your car would be better than mine, if you had the money to put into it, but you don't, and I did. So all around forget everyone, I'd smoke your *** sucka. If you wanna base your argument on your driving skills, go to an all autox forum where real drivers gather, the last time I checked 7thgen was mainly about the 7thgencivic.
Old Aug 21, 2005
robbclark1's Avatar
i will agree with you on one thing...this thread has gotten way off topic...therefore...
GolNat
Nov 27, 2018 03:32 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
cukaracha
Aug 29, 2015 05:27 PM
EM_WON
Jul 22, 2015 06:49 PM
