1,7EL to Civic 2K1
Old Jul 26, 2005
mugencivic69's Avatar
mugencivic69 is an unknown quantity at this point
1,7EL to Civic 2K1
I want to now if the rear suspension of 1,7EL fit on Civic 2K1, i want to have rear dics brake and sway bar.
If anybody make on our car...
Help me please.....
Old Jul 26, 2005
TeLLy's Avatar
Yes, it's an Acura EL
It fits.
http://www.7thgencivic.com/forums/sh...d.php?t=158431
Old Jul 26, 2005
robbclark1's Avatar
Retired suspension supermod.
yes they should fit, however if you don't have ABS currently, then the discs may or may not work right.
http://www.7thgencivic.com/forums/sh...d.php?t=212186
Also if you car doesn't have a sway bar then you will need to add all the parts to hold it into place.
Old Jul 26, 2005
Thanks guys....
Old Jul 26, 2005
Redviking's Avatar
Redviking is on a distinguished road
If you just want to install a sway bar and don't want to mess with the brake system, you can look for another civic that came with a bar....
Check this table:
http://www.geocities.com/bellz252/ar...ybarspecs.html
You can look for a 2001 civic Si (in canada) and recuperate the parts were the endlinks are connected + endlinks, but you will still need to drill the chassis (near the LCA bolts) to install the brackets that hold the bar...
Could be I cheap option!
Old Jul 26, 2005
Salut REDVIKING
On s'est parlé sur Monchar, clubcivicquebec pis icitte......Merci de bonnes infos....
locozoko
Apr 6, 2002 09:00 PM
ZSKCivic01
Nov 4, 2001 08:47 PM
silvervtec01
Nov 4, 2001 06:56 PM
2k1Vtecivic
Nov 3, 2001 10:37 AM
importable
Sep 4, 2001 02:17 PM
