Function7 Control Arms
Old Jul 6, 2005
mkingk2's Avatar
mkingk2 is an unknown quantity at this point
Hey all, I was thinking of going with the Function7 control arms.
http://www.function-7.com/
As far as I can tell the only companies that make them are Function7 and SPC, but I heard that the SPC ones rust quickly.
What do you guys think??
Thanks
Old Jul 7, 2005
robbclark1's Avatar
Retired suspension supermod.
Why do you want them? They don't do anything performance wise, but are generally just show pieces. I haven't heard anything bad about them, but I don't know many people that have them.
Old Jul 7, 2005
mkingk2's Avatar
In fact they reduce unsprung weight. they weigh in at only 1.2 lbs.
Old Jul 7, 2005
Zzyzx's Avatar
Autocross Junky
^^ do you compete with your car? autocross? open track? or what not? if you dont, then you'll never notce the difference performance wise between stock and these. I'd be hard to tell the difference even if you were competing... were talking hundreds to thousands of a second difference, and this is if you are consistant enough.
so do they reduce unsprung weight? yup. will you notice any real performanc difference? Nope, not unless your on a timed run, and even then its unlikely. They do look nice though.
Old Jul 7, 2005
robbclark1's Avatar
The way our control arm is set up, it wont' make that much of a difference. It is one solid piece with that rear arm attached. It isn't like the old civics where the shock attached directly to the control arm. They won't do much at all.
Old Jul 7, 2005
mkingk2's Avatar
Good info thanks. I road course and autocross. Every little bit counts Lots of faster cars to compete against.
Old Jul 9, 2005
Grey's Avatar
DIY King
I have a set of the Function7 rear lower control arms myself. They are so so nice looking. Light too. Lighter than the SPCs. The SPCs won't rust though, they're aluminum. You may have asked someone and they may have been thinking of the upper control arms. Those do rust, yep.
Anyway, to take off the bolts back there you'll need a special socket. That socket is very hard to come by. I e-mailed SPC about it since they supply it with their rear lower control arms. Here's what they said:
-----Original Message-----
From: Cheryl Sheldon [mailto:csheldon@specprod.com]
Sent: Wednesday, April 27, 2005 1:55 PM
To: Terry Johnson
Subject: FW: Form Post From Mozilla
Michal,
Socket #69330 may be purchased from Mohawk Rubber Sales @ ph #781-741-6000
or Myers Tire Supply @ ph #781-961-4464. If I can be of any further
assistance please let me know.
Regards,
Terry Johnson
I haven't installed the Function7s yet myself. I need to call these guys for that socket. I haven't done that either. If someone does, then let me know how it goes...
M
Old Jul 9, 2005
el_ben2's Avatar
CivicMexicano Is My Daddy
el_ben2 is an unknown quantity at this point
Update us on the install...
Curtchuk
Aug 5, 2015 02:14 PM
brainwashedmc
Jul 27, 2015 10:05 PM
califcamper
Jul 21, 2015 10:34 PM
Fred65
Wheels and Tires
Jul 14, 2015 06:40 AM
fordover
Jul 11, 2015 09:10 PM
