Problem with new shocks/coilovers
Old Jun 20, 2005
ShadowfusionX's Avatar
ShadowfusionX is an unknown quantity at this point
Unhappy Problem with new shocks/coilovers
This last weekend I installed new shocks/struts- Tokicos, with Arospeed coilovers on my 2001 Civic (coupe). I used the DIY I found in this forum (awesome, I must say). The front end went well but for some reason when I was done with the back the stems from the shocks were WAAAAY to high up- they actually are rubbing/hitting the metal of the rear seatbacks. The ride height is lower but not excessively low, I would guess approximately a 1.5" / 2" drop from stock. Any idea what this could be caused by? I'll try to get some pictures up this afternoon but if I can't get an answer by then I'll likely just put them all the way raised to prevent damage. Thanks again guys - I've found lots of good stuff from here.
~ Paul
Old Jun 20, 2005
soonercivic's Avatar
soonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the rough
Sounds like you might wanna check your install. Doesnt make much sense to me. When you say "hittiing/rubbing" do you mean when the shock compresses it hits or just all the time?
Old Jun 20, 2005
It is constantly in contact, but bumps accentuate the noise. I do think I did something wrong on the install... I'm gonna take it all apart tonight again. Weeks like this I hate cars .
Old Jun 20, 2005
Yeah, the tokico install is pretty straight forward. If you have problems, contact the seller and they may be able to walk you through it. did you follow this thread in the suspension forum? Look at the pics, see how they compare to what yours looks like. These are the stock shocks he is putting springs on. This will give you an idea of what yours should look like. http://www.7thgencivic.com/forums/sh...ad.php?t=86545
Old Jun 20, 2005
Smile Solved
I got the problems worked out. I didn't have the shock put together right. It took a few tries to figure out where the cone-shaped rubber pieces go and the washer so you can tighten the nut on top down... but i got it finally. Thanks guys.
Diznavis
Jan 25, 2002 11:25 AM
TeamStylesRacing
Jan 20, 2002 08:38 PM
delacampos
Transmission
Jan 2, 2002 02:06 PM
Speedy
Idle Issues
Dec 14, 2001 09:04 AM
Flatlander
Nov 16, 2001 05:38 PM
