shocks and stuff for an '03
Old Jun 12, 2005
tony_buttons's Avatar
I'm unusually bored.
tony_buttons is an unknown quantity at this point
I need some clear answers on the suspension stuff for 2003 and newer civics. Do the civic sedan, RSX and Si all have the same suspension now or what. I read that the bolt size for shocks and struts had changed. Anyway I have an '03, and Im looking to get some new parts. I saw that I could get tokico rears a while back, but not fronts... Are they still not out? I'd rather not have to cut the stock housing as is the case with koni yellows. Are there other options? If I find something for the RSX, will it fit?
Old Jun 12, 2005
jttegx's Avatar
OMNES AD UNUM
http://www.7thgencivic.com/forums/sh...d.php?t=171892
i believe the dc5 (rsx) shares the same suspension as the em2. ive heard of using rsx springs on civics for higher spring rates. but i dont suggest it unless you really know what your doing
Old Jun 12, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
springs (yes)... under brace (yes), strut bar (unsure) Rear strut bar (pretty sure), struts (nooooo way)
Also, RSX shifters are also interchangible with our cars. Anything I left out?
Old Jun 12, 2005
robbclark1's Avatar
Retired suspension supermod.
springs - NO!! They must be linear springs. Progressive springs will make the drop uneven!!
Full coils - YES with modification
Underbrace - YES
Strut bars - some do, some don't
Sway bars - rear yes, front's can if you have DX/LX or with exhaust modification
The only thing that is going to be different is the tie rod ends. The DC5/EP3 have now gone to 16mm bolt holes, but that doesn't guarentee the design of the EP3 stuff has shifted. They started at 14mm bolt holes.
Old Jun 13, 2005
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
i'm putting tokicos on my 03. just need to enlarge the bolt holes to fit 16mm or make a sleeve for 14mm. its not hard to make the holes bigger.
skeener51
Oct 1, 2015 05:56 PM
ken4444
Sep 30, 2015 07:37 PM
Bruce2
Sep 27, 2015 08:45 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 01:28 AM
