cut springs?
Old Jun 7, 2005
nova4dr_racer's Avatar
nova4dr_racer is an unknown quantity at this point
cut springs?
I know this has been discusted many times but this is different.
I was looking in the neuspeed web site and it says it is safe to cut the spring at the progressive part since it has no spring rate at all, its whole point is to determine ride height. (neuspeed sport btw)
I dont like the fact its 1.75 fr & 1.5 back so i wanted to trom the back spring to make them equal 1.75 all arround .. has anyone ever done it? any coments how to proceed. DIY would be nice
Old Jun 7, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
... they do it like that for a reason...
Old Jun 7, 2005
care to elaborate?
Old Jun 7, 2005
es2k2's Avatar
Proud to be a civic owner
weight distribution?
Old Jun 7, 2005
I know but the progressive part has no spring rate at all and they mention it being secure to cut it .. anyone has an idea?
Old Jun 7, 2005
ajhdragon's Avatar
7thgens official a$$hole
i would leave them because the back settles a little lower than the front anyways. if you cut the back it would look like it is sagging.
Old Jun 7, 2005
ok change of senario ... lets say I wanted it to be a lil lower than 1.7" but I cant change my springs .. would you do it?
Old Jun 7, 2005
nick95673's Avatar
nick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to beholdnick95673 is a splendid one to behold
i would buy new springs. honda and other car and performance company pay engineers to design our springs. so cutting them to make them the way you want sounds good to me. i mean if it says you can do it then you can do it but you can also get some cheap fat boy pants and a rope and keep lettin the rope out every year. but that doesnt make it a good idea.
Old Jun 7, 2005
jttegx's Avatar
OMNES AD UNUM
i would never cut a spring unless it is meant to be cut. but in that case if its meant to be cut, that tells me some sleazy man doesnt know how to make springs and thats a sign to stay away from.
i never heard of cutting neuspeed sport springs from anyone here ever since i joined this board. i would not cut them and let them settle as stated above.
Old Jun 7, 2005
noestitch's Avatar
noestitch is an unknown quantity at this point
I have the race springs and when i initially installed them the car was higher in back but now the back is actually a little lower than the front, wether that is the case with sport spings, i don't know.
But yeah, don't cut your rear springs until they are broken in, wait and see what your actual ride height is going to be.
Old Jun 7, 2005
noestitch's Avatar
i thought about this before too. i would do it, but cut 1 dead coil only because it has no purpose other then playing dead.
Old Jun 7, 2005
noestitch's Avatar
Old Jun 7, 2005
c kim's Avatar
c kim is an unknown quantity at this point
It's pretty safe to cut a dead coil off but make sure you don't cut too much off so the back end sags. I think the neuspeed drop is perfect, when the drop in the back is same in the front, the car always looks like it's sagging so reconsider your decision.
Old Jun 7, 2005
flotsamm's Avatar
Like mentioned above, you might be able to cut a small amount off as long as you dont cut too much. Reason being is, if you cut to much off the spring can pop out of the perch if the suspension is ever fully extended. Personally, I'd never do it.
Old Jun 7, 2005
anyone here installed his springs on a sedan ... I wanna see the gap it leaves
Old Jun 7, 2005
noestitch's Avatar
find mine in member rides, only shows front gap
Old Jun 7, 2005
flipcrip's Avatar
flipcrip is an unknown quantity at this point
i've installed neuspeed sport springs on my sedan and the drop is sick.....about 1 finger gap all the way around and an even drop...not like tein s-techs...atleast for a sedan
Old Jun 8, 2005
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
What size tires would that be. That sounds lower than my Race with stock tires.
Old Jun 11, 2005
flipcrip's Avatar
they're actually stock tires aswell.....14"
Old Jun 12, 2005
GaryC17's Avatar
Post us a pic. I'm kinda curious of the sick look.
Old Jun 12, 2005
tony_buttons's Avatar
I'm unusually bored.
tony_buttons is an unknown quantity at this point
I have neuspeed sports on 215/40/18. look in member rides. Dont cut them is my suggestion.
Old Jun 14, 2005
flipcrip's Avatar
i'll try to take some pics this weekend
Old Nov 5, 2005
CivicSF's Avatar
CivicSF should not be trustedCivicSF should not be trusted
stock chop
stock bottom coil chop all the way around. improved handling over stock height for sure. good for the zero cost suspension drop with only cash needed for realignment. just jacked the car high on the lift and cut each spring (two cuts per spring) with the air tool. took about 10 minutes.
Old Nov 5, 2005
robbclark1's Avatar
Retired suspension supermod.
Good for weakening your springs and potentially causing an accident!
Old Nov 5, 2005
DDragon7's Avatar
Even I know cutting the springs are a no no.
Old Nov 5, 2005
booba5185's Avatar
7thgen Terminator Ninja
booba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to beholdbooba5185 is a splendid one to behold
I know as much about suspension as President Bush knows about the English Dictionary, but i would assume the back would be higher because u use your trunk to carry things, those things can be heavy, making the rear go down. I dont know about you, but i very rarely cary anything of significant weight under my hood, except the occasional dead hooker.
Old Nov 6, 2005
c kim's Avatar
i got a neuspeed/tokico setup on my sedan, and the back end could be lower. But the tokico raised the back end up slightly so your car might be different.
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 01:28 AM
Mc7602
Sep 17, 2015 02:01 PM
