18in rims, lowered, camber kit possible?
Old Jun 6, 2005
FLiPKicks's Avatar
FLiPKicks is an unknown quantity at this point
I have 18in RH Evo C3's with 215/40 toyo proxes4's that i just wrapped on this weekend. I was wondering if it's possible if I can put a camber kit. I don't know exactly how many inches my car is dropped because it's on ground control sleeved coilovers, but there is no gap between the fender well and the tire, if that helps. Will rolling my fenders help?
Also, I'm not a guru at how camber kits work, but as I now have a negative camber, from my understanding, whenever the tire hits a bump, the whole rim/tire is angled into the fender well, correct? So if I put a camber kit, when I hit a small bump in the road, will the tire/rim angle in to the well or bounce straight up? I don't know if that made any sense.
Thanks in advanced.
Old Jun 6, 2005
PunkingCivic's Avatar
I need TP for my bunghole
You might be fine
Just roll the inner fender lip
Old Jun 6, 2005
Nodnero's Avatar
Camber kit is easily possible, just roll/cut the inner lip on the rear fenderwells.
Old Jun 6, 2005
jttegx's Avatar
OMNES AD UNUM
the purpose of a camber kit is to align your wheels so it sits at a proper stance. by setting your wheels on a proper stance, it WILL prevent tire wear and even help performance wise for those track heads.
but in your situation, if your wheels arent rubbing and losing tire thread, rolling your fenders would be the best bet as its a cheaper solution to prevent the tires rubbing when riding so low. you said you have negative camber? you could expect negative camber wear in the future if your dropped that low and on 18s.
check out spc and ingalls as they make good camber kits.
Old Jun 10, 2005
bOoStEd042dr's Avatar
bOoStEd042dr will become famous soon enoughbOoStEd042dr will become famous soon enough
anyone else with this setup?
Old Jun 11, 2005
eye_see_you's Avatar
let the devil out
18 " Tenzo R Drivex 7
Tokico Blue HP's
Eaibach Springs
and camber kit forgot who made it
Old Jun 11, 2005
FLiPKicks's Avatar
Anyone know a good website/place to purchase ingall or spc camber kits? And is it hard to DIY install? I know I would have to take it to a tire shop to get it aligned.
Old Jun 11, 2005
FijiBluePearl's Avatar
FijiBluePearl is an unknown quantity at this point
ebay sells new spc camber kits for $100 new (front and rear) if that helps
Old Jun 11, 2005
R1Style's Avatar
Get the SPC kit...
the install is pretty easy... definite DIY. But like you said... you'll have to take it to a shop to get properly aligned.
GolNat
Jan 12, 2021 09:06 PM
TheRubixHorse
Jul 29, 2015 05:22 AM
afinuf12
Jul 28, 2015 04:44 PM
