using washers to fix camber?
Old May 16, 2005
SiG's Avatar
SiG
hey guys
ive heard of ppl doing this on older civics and integras, but never heard of anyone trying it on a 7thgen
Im just wondering if anyone has tried it or know if it works. basically, taking washers and putting them between the upper control arm and the body of the car to rectify camber as opposed to buying a camber kit. Would this really work on our cars?
I know you'd have to keep unbolting things to add more washers when doing the alignment but im just wondering if you kept adding washers and going through this trouble could you really make it work?
Thanks
Old May 16, 2005
flotsamm's Avatar
I think this only works on cars that have double wishbone suspension. Cars like ours that have McPherson struts require an eccentric bolt type camber kit.
Old May 16, 2005
SiG's Avatar
SiG
I should clarify i was referring to the rear of the car, not the front. I need a rear camber kit and this came to my attention and it was interesting. Ill probably go with a camber kit still but im still curious. And as we all know, we have double wishbone in the rear
I found this as well
http://home.earthlink.net/~civicex95/rearcamber.html
Old May 16, 2005
robbclark1's Avatar
Retired suspension supermod.
Not to be mean, but have you looked at the OEM camber kit? I think you should check it out. We don't have double wishbone anywhere on the car. Washers are completely useless unless you can find a way to transverse where the camber kit bolts to the car. Just get a camber kit.
Old May 16, 2005
wonderz's Avatar
wonderz is on a distinguished road
interesting idea.
Old May 16, 2005
SiG's Avatar
SiG
I was under the impression we have double wishbone in the rear with mac struts up front, no?
Well im going with a camber kit regardless but i just wanted to know about this idea a bit more. any more replies are appreciated
Speaking of which, if anyone has a rear camber kit for sale, PM me!
Old May 16, 2005
robbclark1's Avatar
fronts are macpherson. Rears are some kind of large control arm. Look at the picture. There is no double wishbone.
Old May 16, 2005
rickinthescv's Avatar
rickinthescv will become famous soon enoughrickinthescv will become famous soon enough
No, the washer trick does not work on the 7th gen.
Old May 16, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
its a multilink rear and no you cannot use the washer trick.
mistermenphis22
Jul 13, 2015 04:43 PM
Jul 12, 2015 11:54 AM
AaronSorenson
Jul 7, 2015 09:40 PM
bo_red
Apr 23, 2015 10:09 PM
Desi
Dec 20, 2001 05:34 PM
