skunk2 coilovers: rate it if you got 'em
Old May 11, 2005
Skunk2ner's Avatar
Skunk2ner is an unknown quantity at this point
i was thinking about getting skunk2 coilovers, but i hear good and bad things about the. i'm thinking about getting ground controls instead if not skunk2.
how is the ride? what shocks are you using? what issues have you had?
Old May 11, 2005
scatman's Avatar
Still in the game...
junk.
i cant even count how many sets of skunk2 springs ive seen break....and yes, i mean the spring actually breaking from the pressure of it being compressed.
Old May 11, 2005
Skunk2ner's Avatar
Originally Posted by scatman
junk.
what shocks were they using?
Old May 11, 2005
scatman's Avatar
dont worry about the struts......cant have good struts without good springs, imo
Old May 11, 2005
Skunk2ner's Avatar
i was just curious if it was the fact that the stock struts are so damn weak that the springs broke.
Old May 11, 2005
scatman's Avatar
bottom line, dont waste ur money on that crap.
Old May 11, 2005
jttegx's Avatar
OMNES AD UNUM
skunk2 sleeved coilovers on stock shocks
1 year (about 15k miles)
spirited driving habits, never been on track or course. just daily driving with some hard turns at times (freeway exits/etc =D)
IMO, it'll be a rough ride in the long run. the first few weeks were OK, but i can tell the shocks were wearing down and just getting harsher by the month. im not picky on ride quality, but i can live with it. my stock shocks are NOT blown but i can expect them too eventually if i keep up the hard turns on the roads (knocks on wood).
ground controls and stock shocks will just be as bad as skunk2s. if i had the chance, i would've saved up for full coilovers or do it right the first time. reason why i got the skunk2s is cause i got them for a good deal and desperately wanted to drop the car. also keep in mind skunk2 coilovers wont work with some aftermarket shocks (IE: KYB and Tokico Blues?)
price:
comfort: (stock shocks)
quality: (from my exp)
cons:
-front coils will make nasty creek noises when you steer. this occurs because the coil of the skunk2s is rubbing against the spring. a solution is to grease the top mount plates. i never tried adjusting the index thing though...
-my set was hard to adjust, needed a lot of slack to adjust the coilovers. so had to use wd-40 to let them slide up n down
im guessing your going all out skunk2 brand? skunk2 is comming out with full coilovers, not sure for the em2 though, but i bet it'll cost a pretty penny.
rep me if this was helpful
Old May 12, 2005
Skunk2ner's Avatar
thanks for the info jttegx.
i was planning on running with koni yellows the same time that i install either the skunk2 or ground control coilovers. i'm just curious as to why some people have had skunk2's break. usually skunk2 makes great quality parts.
right now i'm kind of leaning more towards ground controls because you can order them at a custom spring rate, which will be good for when i autocross.
Dave Brabant
20
Oct 6, 2015 12:44 AM
Skunkone
Sep 24, 2015 04:38 PM
