Konis Installed Yesterday...... Wow!
Old Apr 14, 2005
dinglenuts's Avatar
dinglenuts is an unknown quantity at this point
Man, these are awesome. I got the full set of konis with progress camber kits all the way around, 17" wheels and seriously nice hankook z rated 405s ventus tires. The car handles like its on rails now. I went to the mall and literally could not squeel the tires doing donuts. Its unreal how much better these are than stock. 100% recommended for anyone looking for a top quality suspension upgrade.
Old Apr 14, 2005
Zzyzx's Avatar
Autocross Junky
Cool, now you get to learn how to tune with them...
Old Apr 14, 2005
skipbarber's Avatar
what kind of springs? or are you riding on stockers?
Old Apr 16, 2005
dinglenuts's Avatar
tenzor 2" drop springs. I'm a little sketchy on the tuning, the mechanic who installed them seemed to think with the 17" rims and drop that I shoukld leave them firm as to not bottom out, any opinions on this?
Old Apr 16, 2005
LiKEaFeRiO's Avatar
Well since you are running on thinner rubber, the suspension would probably have to absorb some of the forces your thick stock rubber could that your current setup can't.
Old Apr 16, 2005
Zzyzx's Avatar
Autocross Junky
... the damper adjustments on Koinis does not adjust Bump valving... Meaning when you hit a bump and the suspension compresses, what valving adjustment you have set on the konis has no effect on how slow/quickly the suspension will react. Thats set by koni at the factory.
What you do adjust is rebound, wich is how the damper reacts when the suspension extends. This is why the adjustments on Konis has a whole lot more to do with handling balance then it does with ride quality.
so any way... Heres how to tune them for handling.
ok, 1st off set your dampers to full soft front and rear. Drive the car. See where its understeering or oversteering. If the car is understeering, increase the valving on the rear of the car, if its oversteering increase the valving on the front of the car. once your find the oversteer/understeer balance you want, you can then increase the valving both front and rear equally to increase the cars responsiveness.
See? Simple
Any way Heres my settings
Street Full soft front 1/2 turn up form full soft rear
Autocross/open track, Full soft front, 1/2 to 1/4 turn donw from full stiff rear, and then adjusted as the track needs.
mjdiaz89
Jun 21, 2016 09:26 PM
OptimisticWay
46
Oct 15, 2015 02:16 PM
mrwhos
Aug 11, 2015 02:03 AM
17
Jul 23, 2015 11:48 PM
EM_WON
Jul 22, 2015 06:49 PM
