Can someone confirm these are Hayames?
Can anyone with Hayames tell me if the parts shown on the photos are correct?
The front springs are red and the rears are black.
Is this supposed to be like that?
Did Hayame ever make them in red and black?
Also, is there any hardware missing in the photo?
I know you need stock upper mounts but everything you need for install is there right?
Thanks guys.
Click for larger image
Thanks guys.
If you look at the bottom of the rears, it says Hayame right on them.
Honestly, save a few extra bucks and buy a set of Tein Basics. You'll be much happier if you do.
Thanks for the reply.
Yeah I know the shocks all say Hayame on them but is the rear spring supposed to be black?
I would go with Tein Basics but this setup is sufficient for me and it saves me a couple hundred dollars to boot.
Suppose to be red. I had both v1 and v2 and they are both red springs. Why they don't have upper mount? They came with them. Also the rear struts color seemed to be diff than the one I had before. Do you have better pic? Like close up one?
This is about the only pic I have.
This is someone elses set that I'm interested in buying.
So upper mounts are supposed to come with them?
I thought you had to reuse your own?
upper mounts are suppose to come with them. i tried the OEM mounts n it doesnt work.
and yes there all suppose to be red as well. maybe your rears were meant for another application or something?
JetsterDajet
52
May 8, 2016 12:11 AM
curaze
Sep 22, 2015 08:27 AM
