eibach prokit springs
simple question for anyone who has them, how do they ride compared to factory and to say arospeed coilovers, which is what i have now cause i needed a stiffer spring for the rear with all my sound but i hate how they ride i want something a lil stiffer than factory and about an inch drop at most and cheap, other wise im putting the factory back on and spacers in the rear, any opinions on this or other springs would be great or if this has been talked about in another thread link me but i did'nt see anything right off hand, thanks
I have the eibachs pro-kit on my 01 coupe lx. The drop wasn't noticable at first but after a month it came down to a two finger gap all around. Yeah I got a system in the back weighs about 25-30 pounds.
ya but 30 even 50 pounds isnt a big deal in the rear heck just my 2 subs way more about 30 pounds, im probably somewhere around 75-100 in the rear, i guess if it starts squating i could space it
Originally Posted by _Viper_
why get better struts Honda has agreed to give me full waranty on my stock shocks with aftermarket springs
how did u get them to warranty them?? do you know one of the service managers or something??
I have prokit. Very good springs as far as better cornering. It's bumpier ride over stock, but I'm already used to that. Drop is great too. For my sedan maybe 2 finger gap in front and 1 in back. I'm on stock struts too for now. I can't say too much about ride quality cause the race seats are causing it more than the springs.
as far as mechanical knowledge and technical stuff i know plenty i worked in a shop and im the only one that touches my car, i just wanna know about that product, i understand that it will be rougher than factory but thats fine, just want sporty feel and more support for the rear
We will warranty the honda suspension but we will not warranty the spring..
The spring is aftermarket so its your problem but as long as the shock is honda we will honor the warranty until the end
They said its not a small drop that will affect in any way how the strut will work..It will only have less travel..
I called three honda dealers and they all said the same thing..
So im not confusing anyone.
Nameless this is what Honda told me..
EtDiGiTaLiS.
I have pro-kit on my car, but somehow the springs are too squeaky? is everyone's like this or is something rediculously wrong with mine? im also on koni yellows if that makes a difference.
^ That is sweet!
I never knew people would have such luck heh.. thanks for the info man... Joined: Aug 2001
Originally Posted by Xenin
does this apply with shocks and springs? like would honda warranty the suspension except the shock and spring?
Ill be more specific..
Honda will warranty every honda part ecept engine Mods example Cam gear etc etc if you install that and the engine blows you are not covered..and it makes sense.
Now if you put an aftermarket spring Honda says all the suspension will still be covered except the spring itself...
They lower vehicles all the time they said so its not because a shock has less travel that its gonna blow unless of course your siting on the ground...
Like they said cv joint shoudn't go bad because of lowering etc etc etc ...
Im real happy anyhow
Oh well i went ahead and ordered some, i will have them monday and put them on, probably wont take me about 2 hours at most to do it, its easy
If taking a hammer to your front end pains you, get the motrin ready. I've done this on other cars before, but I'd have to say the Honda has a tight fit.
EtDiGiTaLiS.
Originally Posted by BeezRide
any suggestions for taking off the 17mm bolt in the back? Im using a really long wrench, but its not budging.... Im hoping that the rust remover does something to help.If so, make sure that you're not trying to unscrew the side that's welded to it
If not, then disregard and use some elbow grease
EtDiGiTaLiS.
wow sorry ya'll are having so much trouble, helps if you have the right tools, it took me about 45min ish to do the fronts but i have a cordless impact and i've done it before and the back took me about an hour, but i have more tools than most shops, but i used to work at a shop, i have a tool box that is 6.5 ft tall and 4.5 ft wide and 3 ft deep and its packed, i also have a obd2 snap on microscan, impacts, over 300 sockets screwdrivers, welders, torches, cutting and welding torches, dewalt angle grinder, wire pullers, and just about any specialty tool you need to work on a newer honda or kawasaki motorcycle, and the tech books for them, so if anyone needs some help tech wise or locally gimme a shout
oh ya and the ride is hella lot better than any coilover ive ever messed with, just hope it doesnt start squating in the rear
Originally Posted by muzhik
i did mine this weekend... only rear ones, couldn't take off the tie rod on the front... will get a tool tonite to finish it... looks funky,
I just couldn't bring myself to smack it with a hammer.
EtDiGiTaLiS.
