TEIN FLEX finally done.
Old Mar 9, 2005
rijowysock's Avatar
ThE FaMiLy SeDaN
ok guys welll...i finally got all the TEIN on and remanufactured and EDFC installed
rear install=they had to send rear bottoms back to japan to be remachined to narrow the bushing(apparently FERIO's have wider rear under bushings... the reduced the size 4.8mm)
but now they fit and max drop is about 5/8" too low for me.. which is a good thing... ima raise her after settling
the fronts: max drop is about 2.5" actual... but i am going to remove 2 of the 3 perches to lower the ride height in front .5" of course after settling so i can make sure its not gonna lower more..
Pillowball mounts cause extreme road noise on rough roads...im going to try and put 2-3 sheets of tarmat on top of the pillowmounts inbetween car to maybe absorb some vibrations...
the Spring rates are extremely stiff and i think i might buy some 8/10 to replace the OE 12/14 that come w/ the coilovers... even on 16(softest EDFC setting) thew ride is somewhat harsh.... its smooth w/ less jerkyness... but when the road height drops (i.e. i was going 90 on a tollroad and the road height after a bridge dropped approx 8" i was airborn literally for 5-10ft. kinda fun but everything in my car was airborn too... )
the alignment does not want to center up (1/2" toe in min.) but i then adjusted the pillow mounts to center (0) and theni was 5/8" tow out... which i took back to align shop and got her aligned 3/16 toe in so it rides nice.. my camber in front is still negative 1.6/1.7 (more on right so that car drives straight(roads angle to right i digress)
so in a nut shell you can still run neg camber w/ perfect toe... its very adjustable the alignment guys were in awe of all the adjustments
ride height ranges from the max drops^^^ to actually above oem height..
you can even raise 3" higher than oem(maybe if you were in a snowy area and wanted a 4x4 for winter it would eb helpful, this requires maximizing height and then minimizing preload.
the sring rates as stated are 12/14 but at fully firm... she rides like a go kart=very sexy imo.. its nice and then at soft she rides... like tein SS..
one last thing. but you cannot purchase this kit until they recall all sent to cali and remanufacture the rear bushings...approx time of sale=august/september.
hope this helps all of you AutoX peeps and people like me who just lke tohave fun on the road.. i will post pictures once i raise rear/lower front and get my new 8/10 springs.
riley
BTW EDFC cleared hood fine on the new and improved ES1/EM2 fronts and rear EDFC is perfect as well...
Old Mar 9, 2005
MishBallzEM2's Avatar
I'm The Ballz Of 7th Gen
MishBallzEM2 is an unknown quantity at this point
nice..cant wait to see the pics
Old Mar 9, 2005
HondaKorn's Avatar
Life is better with 5lug
sweetness!
Old Mar 9, 2005
02civic_rida's Avatar
way to go homie
Old Mar 9, 2005
rijowysock's Avatar
ThE FaMiLy SeDaN
all my FL peeps will see em at the "ride" meet on 18th
Old Mar 9, 2005
on the 18th of what march????
Old Mar 9, 2005
dj02's Avatar
pics yo!
Old Mar 9, 2005
Caucasian.Asian's Avatar
sounds good. can't wait to see some pics.
Old Mar 11, 2005
ViNRoCk8's Avatar
#1 S2000 Fan
cool, lets see some pics
Old Mar 11, 2005
rijowysock's Avatar
ThE FaMiLy SeDaN
i got sum but my acct is full .... ima take soem ebtter ones and pist em uo this week coming up
Old Mar 11, 2005
JCiv03's Avatar
Nice! how does this compare to your old B&Gs?
Old Mar 11, 2005
R1Style's Avatar
sick!!!! EDFC too... post some pics!
Munzy
21
Oct 7, 2015 07:48 AM
Cam Diaz
Sep 29, 2015 07:17 PM
carid
Sep 28, 2015 10:13 AM
2002ExCivic
22
Sep 28, 2015 08:29 AM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
