camber adjustments
Old Feb 25, 2005
jayjdlc's Avatar
jayjdlc is an unknown quantity at this point
camber adjustments
i just bought a tein flex dampers coilovers for my honda civic coupe but i have not installed it yet and i have a 215/45R17 tires. i just would like to know if i need my camber to be adjusted and if i need to buy a camber kit???
Old Feb 25, 2005
Boilermaker1's Avatar
Jap-Euro Fusion
You need them for the rears. The fronts have camber plates which adjust to correct (or add more).
I still don't comprehend how people could spend so much money on something they don't understand.
Old Feb 26, 2005
ojay's Avatar
ojay is on a distinguished road
flex eh? you do not deserve your setup...
Old Feb 26, 2005
tfnaaf's Avatar
BLDNPSI Mod
ANYtime a susspension change is made at the min you need to have the alignment checked! This includes ride height adjustments
Old Mar 18, 2005
rijowysock's Avatar
ThE FaMiLy SeDaN
fronts... u got camber mounts... adjust em to zero first tho... then align from there... and then u can adjust in/out AND not have "horrible" toe
rears u need a camber kit..
also make sure to check your rears that the bushings fit.. i got the first set and they had to send mine back to japan to remachine the rear bushing
they said they were gonna pull em off the market until they coud redo em... hopefully yours were redone..
if the sides of the rear bushing are polished looking then their redone.. normally they were black powdercoated..
u really need to look up ur **** tho... kinda dumb spending mad $on a kit made for the best of the best... did u get the 12/14 springs or customize em..
im redoing my fronts to 10... so if you want some 12kg/mm springs ill sell u mine..
riley
Old Mar 19, 2005
1955's Avatar
all the man asked was some advice,praise the lord.cruel world.anyway,install them first and check for alignment as someone said up there,enjoy the new bouncy ride coz the money is spent.
Old Mar 22, 2005
peteriap's Avatar
peteriap will become famous soon enoughpeteriap will become famous soon enough
Contact us when you are ready. I will take care of you on the camber kit.
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
TheRiddicles
Sep 21, 2015 01:28 AM
