Springs Help
Old Feb 1, 2005
nindoo's Avatar
Why is my vagina bleeding?
Springs Help
Hello, I currently have a Honda Civic EX Coupe 2002. My front anti-roll bar is 25.4mm I have a 22mm rear bar. My next modification is shocks and springs. I plan on getting Tokico HPs, but I wasn't sure what springs were right for me. I need a comfortable car with improved handling. Mostly I will be using my car for daily dricing and occaisionaly as a weekend racer for road racing. I was looking for springs that would not reduce the life of my shocks, reduce body roll, but not so much so that my ride quality is significantly reduced(really poor road conditions in Montreal Canada).
Here are the springs that I have looked up. I couldn't find the spring rates for the Neuspeed and Eibachs.
Tein STech
Spring Rates
FRONT
kgf/mm,lbs/in
2.8/157
REAR
kgf/mm,lbs/in
5.2/291
Ride Height
FRONT
-1.3
REAR
-1.4
Eibach Sporlines
Spring Rates
Ride Height
FRONT
-1.4
REAR
-1.4
Neuspeed Sport
Spring Rates
Ride Height
FRONT
-1.75
REAR
-1.50
Old Feb 1, 2005
SaRno03Vic's Avatar
** ThE SeAsOn VeT **
SaRno03Vic is an unknown quantity at this point
Get the Neuspeeds......Tien doesnt seem to full the gap some are looking for
Old Feb 1, 2005
shmik1's Avatar
I love my sportlines, they are a bit harsh at times cause our roads suck, if you want a performance spring that makes it really fun to drive dont expect a smooth ride.
and I forgot already but Tokico has a warning and it might be 1.5" drop MAX. I dont remember, I could always find my instructions and check for ya... maybe it was 1.75.. prolly 1.75 cause i know sportlines are DEFINITLY in the clear
if it is 1.75.. i'd do Neuspeed Sport, just cause they're lower, if you're looking for performance and a smooth ride compromise... maybe get Eibach Pro Kit, or 1" drop or maybe 1.3"ish? H&R? not really sure wut adice to give ya.
Old Feb 1, 2005
stlblues13's Avatar
stlblues13 is an unknown quantity at this point
Go with the Nuespeeds.
Old Feb 1, 2005
dezod's Avatar
7thgen Power Maker
Tein STech
Spring Rates
FRONT
kgf/mm,lbs/in
2.8/157
REAR
kgf/mm,lbs/in
5.2/291
Ride Height
FRONT
-1.3
REAR
-1.4
Eibach Sporlines
Spring Rates
Ride Height
FRONT
-1.4
REAR
-1.4
Neuspeed Sport
Spring Rates
Ride Height
FRONT
-1.75
REAR
-1.50
You have an upgraded rear sway, I see.....if you want a front one, we have a sale on 27mm Progress ones.....
Old Feb 1, 2005
robbclark1's Avatar
Retired suspension supermod.
Nindoo, there are not spring rates for progressive springs. They just come in %. You should call the company and ask them what percentile their springs fall in. Usually it is around 25-35% stiffer than stock. Say a spring is 30-35% stiffer than stock, when fully extended it is 30% stiffer then stock, but when fully compressed it is 35% stiffer than stock. From what I know of both, go with the cheaper ones. They are about equal other than that.
Old Feb 1, 2005
peteriap's Avatar
peteriap will become famous soon enoughpeteriap will become famous soon enough
^^ I agree.
You will be happy with a set of Neuspeed Springs. Neuspeed sport for the daily driver trying to keep his ride quality as smooth as possible. Neuspeed race for the more agressive driver who isn't as concerned with ride quality.
Old Feb 1, 2005
flotsamm's Avatar
Eibach once told me that their Prokit is 10-15% stiffer then stock and the Sportlines are 20-25% stiffer. FWIW..
skeener51
Oct 1, 2015 05:56 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
beanhead
Sep 24, 2015 12:04 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
