Just want to confirm
i have a 03 ex, so i'll need some 01 uppermounts to install my tein basic. I want to comfirm if i got the part right and if i need all of these, cuz DAMN !! they cost 170 bux !
anybody know if the 01 sedan use the same part?
Front:
369032 Part 9 (BEARING, FR. SHOCK ABSORBER MOUNT) $13.98 X 2
369034 Part 10 (MOUNT, R. FR.) $23.45 X 1
369034 Part 11 (MOUNT, L. FR.) $23.45 X 1
Rear:
36557 Part 1 (WASHER, SHOCK ABSORBER MOUNTING) $0.27 X 2
22692 Part 2 (COLLAR, SHOCK ABSORBER MOUNT (DUFFY STEEL PARTS) ) $0.45 X 2
369095 Part 8 (RUBBER, SHOCK ABSORBER MOUNTING) $4.74 X 2
369097 Part 9 (BASE, RR. SHOCK ABSORBER MOUNTING) $18.62 X 2
369099 Part 10 (AL, SHOCK ABSORBER MOUNTING) $3.80 X 2
369101 Part 11 (PLATE, SHOCK ABSORBER MOUNT) $1.79 X 2
369103 Part 12 (RUBBER, RR. SPRING MOUNTING) $9.71 X 2
369105 Part 13 (COVER, RR. DUST) $7.22 X 2
369109 Part 15 (PLATE, BUMP STOP) $2.15 X 2
Front:
Rear:
with all those ppls with tein, no one could confirm this?
also, has anybody have any problem ordering from http://www.hondaautomotiveparts.com/ aka Majestic Honda
Ok, here's the deal. You can just buy the bearings and take apart your stock mounts. That would mean having to disconnect the mount from the spring/shock. Or you can buy it all and just do an even swap.
As for the rears, I thought they came with upper mounts. I don't have the teins so I don't know.
ok, say i take apart my stock mounts, which PART DO I NEED TO ORDER. and no, the rear of tein doesn't have mounts either. Anybody know which part # i need?
thank in advan
i didn't have to order anything, my teins came with 2 sets of upper spring seats or what they are called, but one was goldish orange and the other green i used the green one on my 03 lx and worked just fine with the front upper stock mounts
JetsterDajet
52
May 8, 2016 12:11 AM
curaze
Sep 22, 2015 08:27 AM
