RSX Sway Bar Q'....
Old Jan 3, 2005
CivicMexicano's Avatar
El Pinche Turbo Mexicano
CivicMexicano is an unknown quantity at this point
RSX Sway Bar Q'....
If i replace my stock rear sway bar with a RSX-S sway bar do i nedd to replace the bushing or endlinks??
Is so do i replace the with RSX one or are there aftermaret ones...
Old Jan 3, 2005
K20me's Avatar
You'll need to use the bushings for the rsx sway bar, ours are too small I believe. You don't HAVE TO replace your endlinks, but if you plan on doing so hit Grey up. I think he's still selling some.
Old Jan 3, 2005
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
^ yup.. you need the rsx's bushings which should be 19mm.. I didnt need to replace my endlinks but a few members had some problems with them breaking so dont be surprised.. good luck with the install! worth the money and time
Old Jan 3, 2005
TeLLy's Avatar
Yes, it's an Acura EL
BTW there is also an Energy Suspension polyurethane bushing kit (look for the 19mm application obviously) so if you wanted polyurethane instead of OEM rubber bushings, you can get that. Warning, it gets a little noisier, but polyurethane should outlast rubber. Can't say I noticed a huge gain in performance from switching to it though.
I snapped two sets of endlinks using a 19mm rear sway bar (one RSX, one Neuspeed). By the time I'd switched to my DC5-R sway bar, I had already purchased and installed Grey's endlinks, and I can't be happier with their performance. I highly recommend them, for peace of mind, if anything. I couldn't snap these things if I tried.
Old Jan 3, 2005
gh0st's Avatar
TAQUITOS!!!!
i'm using my stock endlinks and the energy suspension bushings that telly spoke of...so far my endlinks are still intact
Old Jan 5, 2005
CivicHX01's Avatar
then your not driving fast enough on those corners
my rsx bar has been sitting in my garage for almost a year now lolz... need to install that thing...
Old Jan 5, 2005
TeLLy's Avatar
Hurry up and install it, feel the crazy cornering power!
Old Jan 5, 2005
someguy's Avatar
someguy is an unknown quantity at this point
hey let me have it if your never gonna install it.
Old Jan 5, 2005
Zzyzx's Avatar
Autocross Junky
I ran the RSX bar for 6 months worth of autocrossing, with the stock endlinks. You dont need to change them for that bar.
SammySC
121
Apr 7, 2017 07:43 PM
Raiool
Oct 1, 2015 10:42 AM
juicetayne
Sep 30, 2015 11:02 AM
rovafa2002
Sep 28, 2015 06:57 PM
Viczhou
Sep 2, 2015 07:55 PM
