Question About 215/45/17 tires
Old Dec 31, 2004
SaRno03Vic's Avatar
** ThE SeAsOn VeT **
SaRno03Vic is an unknown quantity at this point
Question Question About 215/45/17 tires
I have these Tires with the Rims off my car for the winter.....Im thinking of installing Neuspeed Race Springs Soon is there any problems with this tire size and these springs?? Thanks
Old Dec 31, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
There could be. You gotta be a little more specific than these rims. What rims, and whats the offset on them? Do you plan on putting the alignment back to stock or leaving it a little cambered?
Old Jan 1, 2005
SaRno03Vic's Avatar
Rims are the ones in my avatar picture...Speedy Hi-speed Racing 17x7.0
Im gonna leave it how it is after the drop i just wanna know if i would have to roll the fenders and how it will sit
Old Jan 1, 2005
jttegx's Avatar
OMNES AD UNUM
i have the same tire size but 7.5" instead of 7.0.
with the race springs, i beleive you would rub on the front if you corner hard. the car flexes and the tire will rub against the inside of the fender in the front. as for the rears, it wouldnt rub if you have a little negative camber. so if you got an rear camber kit, adjust it so it sits a little negative. if your worried about the tires that much, then rolling your rear fenders would be a good idea.
from the top of my head, the way it will sit is pretty much no gap all around. i had a myth where when i adjusted my rear camber kit so its more negative, the car sits lower. that or illusions just owns me.
Old Jan 1, 2005
EL_03's Avatar
EL_03 is an unknown quantity at this point
I had those tire size on 17x7.5 with a 40 offset, with H&R sport and i can barely put one finger in between the fender, and also cambered!
Old Jan 1, 2005
SaRno03Vic's Avatar
so you think i should go with the sport springs?
keep the input commin.....im in sort of a pickle
Old Jan 1, 2005
EL_03's Avatar
If you don't like the tucked in tire effect...then sport springs should be ideal!
Old Jan 1, 2005
SaRno03Vic's Avatar
whats the problem with the tires the 215 or the 45
kepp it commin...thanks for ur help
Old Jan 1, 2005
EL_03's Avatar
The 215's
bsmiley
Apr 27, 2015 01:27 PM
bo_red
Apr 23, 2015 10:09 PM
viper775
Dec 9, 2001 10:52 PM
NightKids2
Dec 8, 2001 05:50 AM
technosilver
Nov 14, 2001 10:58 AM
