camber kit front vs back
Old Dec 28, 2004
speshL K's Avatar
speshL K is an unknown quantity at this point
every1 says the back is needed forsure..
but sum say the front is wutevers.. can be ok with or without..
y is that?
Old Dec 28, 2004
7Gnoob's Avatar
7Gnoob is an unknown quantity at this point
The front suspension design does not camber as bad as the rear when lowered.
Old Dec 28, 2004
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
i have been lowered 2" all around for 10,000 miles and i have no problems whatsoever with my front tires getting camber wear. if it even did, it'd most likely be the toe since i have never gotten a alignment yet. from the naked eye, the front wheels sit very very very little negativealy*. but no sign of camber wear at all. i bought a front and rear camber kit set and i compared the front spc camber bolt to the stock ones, looks pretty much the same. so i just left the stock one on their.
save yourself the $20 for the front camber kit and spend it on something more important. definately think about investing into a rear camber kit.
Old Dec 28, 2004
blackbullet's Avatar
The Legend
Pretty much sums it up.
Old Dec 28, 2004
Mr.Modify's Avatar
^^werd....i just got it for my back. Sold the front.
Old Dec 28, 2004
speshL K's Avatar
thanks guys very helpful..
i figure that even tho u can see the little negative camber on the fronts.. the weight of the car probably flattens it out or sumthing... correct me if im wrong
Old Dec 28, 2004
def01tones's Avatar
You bought a used dog??
def01tones will become famous soon enough
Alright! all my camber questions answered!
Old Dec 29, 2004
robbclark1's Avatar
Retired suspension supermod.
Active camber gain in the front is minimal. If you want to autox/road race than a camber kit will allow MORE camber too. It would be nice to have because then you can play with the settings easier and it is only $20-30.
Old Dec 30, 2004
nindoo's Avatar
Why is my vagina bleeding?
will the rear ingalls camber kit for a civic fit the rsx type S?
Old Dec 30, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Yes, its the same part.
Old Dec 30, 2004
nindoo's Avatar
Wicked Boilermaker your the man!!!!!!!!!!
Old Dec 30, 2004
dinglenuts's Avatar
dinglenuts is an unknown quantity at this point
so everyones opinion is if your running 17"s with nice tires, it would be worth the rear kit, but won't really screw up the tires if you don't get the front kit? Right now my 15"s are on, I'm 2" dropped and can't really tell if its messed up my tires.
andylao
Nov 9, 2001 07:36 PM
JeffSpeed21
Nov 4, 2001 10:32 PM
JeffSpeed21
Bolt-on Engine Performance
Nov 4, 2001 12:33 PM
SneakerPimp
Nov 3, 2001 10:57 AM
ImmortalEX
Oct 31, 2001 10:00 PM
