Bad camber with Tein SS and SPC camber kit
Old Dec 22, 2004
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
Exclamation Bad camber with Tein SS and SPC camber kit
I just had my car aligned and they said that they were unable to adjust my camber to factory specs. The front camber is -1.7 and -2.0. What could be the reason that they couldnt adjust the camber kit more? I just dont want to wear out my tires.
Old Dec 22, 2004
syncmaster's Avatar
syncmaster is an unknown quantity at this point
Don't feel bad.
I got a free alignment yesterday on a honda hoist, factory specs, and it still doesn't look right. LOL
Old Dec 22, 2004
djmota's Avatar
they probably did not know how to adjust the camber kit. Both front and back spc kits can handle any drop...as long as nothing is bent.
Old Dec 22, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
The car is probably too low. Camber adjusters can only go so far. If they 0 your toe, then the camber angle is fine. I've had mine at -2 since june and I still can't tell anything is uneven with the tires.
Old Dec 22, 2004
Boost_Junkie's Avatar
Boost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura aboutBoost_Junkie has a spectacular aura about
it should handle it...they just dont kno what they are doing
Old Dec 22, 2004
Vinnie's Avatar
My toe is good, its at .01 and .02
Old Dec 23, 2004
peteriap's Avatar
peteriap will become famous soon enoughpeteriap will become famous soon enough
Thats pretty much true. As long as your not totally slammed, you should be able to get all of your camber back to spec. Get a second a opinion.
Old Dec 23, 2004
taz757's Avatar
Ah, dude. Don't tell me this. I've got a set of Tein SS sitting in the corner of my room and a SPC kit on my car. I hope I don't have this same problem. But then again, I'm not really looking to dump the car anyway.
Old Dec 23, 2004
djmota's Avatar
TEiN IMO doesn't even go that low. If you pick a good alignment shop and show them how to adjust the kit you will be fine.
Makeice3498
Jul 2, 2015 11:13 AM
cukaracha
Jun 7, 2015 03:32 PM
elitezdc5
May 26, 2015 05:46 PM
ernhole1
Dec 6, 2001 12:05 PM
