Front Tein SS "Clank noises", NEED HELP! Car very shaky...
Old Dec 14, 2004
Vinnie's Avatar
Vinnie should not be trustedVinnie should not be trustedVinnie should not be trustedVinnie should not be trusted
EDIT: I managed to get all of the front installed. But now when i go over bumps, i hear "clanks" in the front. What is making sound? Any help would be appreciated...i have more description on the problem on pg 2.
Im in the middle of installing my tein ss and for some reason i cant get brake assembly to push back up. any ideas?
Old Dec 14, 2004
robbclark1's Avatar
Retired suspension supermod.
wiggle the arm of the strut. And gently tap with a hammer, but don't bend the threads.
Old Dec 14, 2004
Vinnie's Avatar
new problem with pictures:
Old Dec 14, 2004
Vinnie's Avatar
i think this is the problem:
this is under the car...i dont know how to make it coil like its suppose to, wtf did i do wrong
Old Dec 14, 2004
Civic04's Avatar
Civic04 is an unknown quantity at this point
I cant see in the pics but do you have your axel nut on already? if you do take it off and let it free slide in the hub. take the axel out of the hub ad it shold coil back together then put the knuckle up to the strut and put the axel in the hub at the same time (all in one motion) you can also spin the rotor while putting the knucle up to the strut that might work
Maybe you pulled the axel apart dont know how though
Old Dec 14, 2004
Vinnie's Avatar
i think i missed up part of the drive shaft
the boot thing in the upper left, close to the "8"s
Old Dec 14, 2004
bgoetz's Avatar
bgoetz is an unknown quantity at this point
you pulled out the ball joint. It should go back in place just push on it kind of hard.
Old Dec 14, 2004
scatman's Avatar
Still in the game...
damn dude, ur axle popped the fvck out. it happened on my Si when i did my springs, easy fix.
Old Dec 14, 2004
bgoetz's Avatar
just keep slightly turning the rotor and pushing in on it kind of hard it will slide back in when you get it in the right spot. You cool you did not break anything
Old Dec 14, 2004
bgoetz's Avatar
HAHA I like the work gloves bet those don't last to long lol
Old Dec 14, 2004
Vinnie's Avatar
yea the work gloves were black, thats like the third pair. Anyway ill try to turn it and push...
Old Dec 14, 2004
Vinnie's Avatar
so how do i fix it?
Old Dec 14, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
You need to pop the axle back in. Thats why everyone says you have to tie up the brake. Basically you need to rotate it around and push... somewhere, it'll index back in.
Old Dec 14, 2004
bgoetz's Avatar
yep WHAT EVER YOU DO DON'T TARE THE BOOT. it would be hard to do, but you never know.
Old Dec 14, 2004
Vinnie's Avatar
still workin on it, any tips? My hands are starting too burn
Old Dec 14, 2004
bgoetz's Avatar
I got my terms mixed up you are trying to put the outboard cv joint back in. Still the same way that I said except to make it easier you may need to unbolt the lower control arm from the subframe and disconect the anti sway bar from you lower control arm. Three bolts total 1 for the sway bar and 2 for the control arm you rotor should only be held up by the inboard joint that goes into the tranny at this point. Now you can move it freely and work it back into place. NEXT TIME SUPPORT THE ROTOR WITH SOMTHING SO THE WEIGHT AND OR SUDDEN MOVEMENT DOES NOT PULL THE JOINT OUT.
Old Dec 14, 2004
bgoetz's Avatar
going to bed now hope everthing turned out ok. Be more careful next time
Old Dec 14, 2004
Vinnie's Avatar
alrite, the fronts are installed, got everything working correctly. However, when i was driving around i heard like "clank" noises. The only thing that i think i might have done wrong was the tie rods. Are those suppose to sit right at the strut? I think i may have a gap. Are there other souces that could be causing a bad sound when i go over bumps?
Old Dec 15, 2004
Vinnie's Avatar
need help from anyone awake at this hour...guess my car wont be leaving the garage anytime soon.
Old Dec 15, 2004
jdm_bb's Avatar
jdm_bb is an unknown quantity at this point
you should if took it to the shop!
Old Dec 15, 2004
Vinnie's Avatar
yea, im losing hope/confidence. Most likely Ima take it to the shop tomorrow, let them finish the install and correct watever the fck i messed up. Sigh*
Old Dec 15, 2004
Jap-Euro Fusion
If its banging over bumps, something isn't tight. The spring is loose on its perches, the knuckle bolts aren't torqued down or the top mount still has some play in it. Check that everything is tight and torqued to spec. With the axle falling out... it leaves an extra big element to check that you're going to have to look into... because that could be the problem.
Old Dec 15, 2004
Vinnie's Avatar
was i suppose to torque the top bolts when the car was on the ground? or on the jack stands?
Old Dec 15, 2004
Vinnie's Avatar
After further driving, my car seems shaky and bumpy too...does this mean i didnt torque everything down securly?
Old Dec 15, 2004
TeLLy's Avatar
Yes, it's an Acura EL
Could be - jack the car up again, check the torque specs for each bolt you'd loosened and tightened, and make sure each and every one was up to spec.
Is this your first set of coilovers? I don't mean to sound like an ***, but I remember my first time driving a car on full coilovers, I asked the owner if something was wrong, cause of how bumpy the ride was. A little more bumpity-bump is par for the course...I don't know what you mean by "shaky" though....do you find yourself losing a bit of control on bumps or small slopes? More details please!
Old Dec 15, 2004
Vinnie's Avatar
When i drive, it feels like the car isnt as stable as stock. Its almost as if my car is wobbley...
Old Dec 15, 2004
TeLLy's Avatar
Ahhh....well again, check that everything is tightened down. Also, is this "wobbly" feeling as if your car is moving left and right? COuld be your alignment....and I would say definitely get that axle looked at, considering it did come out before.
Old Dec 15, 2004
Vinnie's Avatar
its not that i didnt expect a lil bumpy ride, i just didnt expect so much noise
Old Dec 15, 2004
HyaBoosta's Avatar
did you use an impact gun to do the work? It does sound lke you left something loose. When we did my freinds we tightened everything up while it was on the lift. It might have been the sequench that you tightened everything up in thats the matter too. If weight was holding something down while you were tightening it up then you may not have been able to tighten it up all the way.
Old Dec 15, 2004
bgoetz's Avatar
that sucks it is really hard to say just what it is without looking at it. Did you use a torque wrench??? It is important that all of the bolts are the correct spec, but it does not matter when you tighten them (on the ground or on the jack) as long as they are to spec. Also depending on how you put your cv back into place if it is a constant bumping as if you are driving over rocks I would say that you messed the cv up. Sorry I can't be more help. Becareful driving to the shop somthing breaking on the way would not be good at all
