rear rsx oem sway 19mm... direct fit?
OMNES AD UNUM
i need some clearification and wanted to know if the OEM rsx rear sway bar will fit my 2003 ex coupe using the stock hardware (nuts, bolts, bushings. etc) giving me a direct OEM-like fitment?
are their any other concerns i should think about? such as better endlinks or bushings since i read upon some research how the stock civic bushings were plastic crap
You should use the bushings and brackets from the RSX. The bigger bar might bind too much in the smaller bushings. Or you could find poly bushings with greaseable fittings at an auto parts store. Either route you choose, this is an excellent upgrade.
1) Yes it is a direct fit on EX
2) You just need new bushings, the brackets will work
3) Bushings aren't made of plastic, but either rubber (OEM) or polyurethane.
4) You won't have a problem with stock endlinks. Endlinks are only problem with the progress bar or sometimes bars larger than 21mm.
OMNES AD UNUM
thanks for the info guys
my last questions:
would the bushings from the rsx work fine?
would i be better off using the rsx brackets or my civic brackets?
how much ft/lbs torque should i give when installing?
my last questions:
Search and Learn
my last questions:
my last questions:
Yes
33ft/lbs
Originally Posted by civicvtec1ps
Yes
Yes
33ft/lbs
Yes
33ft/lbs
cmart1209
May 29, 2015 04:52 AM
oneheadlight
Apr 29, 2015 11:30 PM
