trimming the bumpstops...
Old Dec 5, 2004
infinite's Avatar
infinite is an unknown quantity at this point
i'm pushing an '02 civic sedan lowered on neuspeed sports and i had my front struts replaced under warranty earlier this year. i was told that honda uses rsx type replacement struts. i just read the guide that came with my springs and i noticed that it mentioned that the rsx requires that the bumpstop be trimmed when using the springs.
when i got my neuspeed sports installed on my sedan i think the mechanic forgot to trim my bumpstops. is this going to be a problem? what can happen if i don't trim my bumpstops?
Old Dec 5, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
i didnt trim my bumpstops
for the neuspeed sports it shouldnt be a problem
the only reason to trim the bumpstops is to get the car lower on coilovers
Old Dec 5, 2004
infinite's Avatar
thanks for the info.
i think my struts are bottoming out sooner now when i go over speedbumps, big dips in the road, or doing sharp turns, because of the shorter spring and longer oem bumpstop. when the weather got cold i think it stiffened the rubber bumpstop and when the strut hits it, it makes an annoying squeaking sound. the sound is sooo annoying. i blast my music so loud that i've started to get a ringing in my ears. i hope i'm not starting to go deaf.
Old Dec 6, 2004
WannaBFast's Avatar
i have neuspeed sports.. and i have never bottomed out the struts on the bumpstops yet
are you sure its not just the stiffness of the springs?
Old Dec 6, 2004
civicvtec1ps's Avatar
Search and Learn
Didn't cut mine at all.
Old Dec 6, 2004
infinite's Avatar
i noticed you have the exact same car as mine. it's even the same year(i can tell by your wheel covers) i started to notice this squeaking noise when i changed my summer rims to my oem winter rims. do you hear any squeaking noises from your front end when you go over speedbumps or big dips in the road? the squeaking seems to get louder, the colder it gets.
btw: did you ever get your front struts replaced under warranty? i had mine replaced recently and i think they are different from the ones that initially come with the car. i was told that they are the ones they use on the RSX.
Old Dec 6, 2004
cdmx's Avatar
I didn't trim mine as well
1.75" drop goldlines
Old Dec 7, 2004
WannaBFast's Avatar
well if its squeakin.. its probablly the sway bar bushings, no they arent the same struts as the rsx, the rsx has a larger diameter hole where it meets the steering knuckle, they are similar, but not the same ones, my struts were replaced under warranty.. right before i installed the springs
tuvok
Sep 25, 2015 03:13 PM
rayman009
Sep 12, 2015 08:30 PM
h4ldol
Sep 10, 2015 12:25 PM
honda.lioness
Aug 21, 2015 02:36 PM
Amulon
Aug 18, 2015 11:03 AM
