front hayame uppermounts compatible with rears?
Old Nov 5, 2004
jttegx's Avatar
OMNES AD UNUM
quick question, can the front uppermounts off the hayame coilovers woth with the rears hayames? if so, what else is their to it?
thanks in advance
Old Nov 5, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Fronts are held in by 3 bolts up top
Rears are held in by 2.
So if you're asking if you can use front mounts on the rear, the answer is no.
Old Nov 5, 2004
jttegx's Avatar
OMNES AD UNUM
k, i was messing around with the hayames for few minutes and finally found the piece i wanted... the washer and the other ring thats like 5cm thick that wraps around the loop hole on the hayame strut. i took the washer and the 5cm thick ring from the fronts and wanted to see if my rears will hold up with them using rear oem uppermounts?
ill post pics of what im talking about tomorrow, its too late and i need sleep bah
edspyhill09
Jun 12, 2016 02:45 PM
7thgensurvivor
38
Aug 29, 2015 11:50 AM
Jeffdp
Aug 5, 2015 11:38 AM
Mercilus
Jun 7, 2015 10:00 PM
rhvic
May 22, 2015 03:06 PM
