Installing aftermarket springs
Old Nov 3, 2004
Blahman2's Avatar
One Slow Civic.... But I can take turns pretty well :-)
Blahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trustedBlahman2 should not be trusted
Please don't close my topic, I still have questions!
alright, I noticed you don't need a compressor for removing the stock springs, but how hard is it to do it without a compressor with the aftermarket springs? I just don't wanna have it apart and then realize I can't do it.
Old Nov 3, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Learn to read DIYs
20) Now for the scary part. Taking apart the strut. That 17mm nut on top, the one that we first loosened in the beginning, is the only thing keeping the strut from springing apart (no pun intended). Some say you should always use a spring compressor when doing this. In fact, I say you should always use a spring compressor, but as the writer of this DIY, I am telling you it's not necessary with the 2001+ Civics, as long as you have someone sit on the spring, or as I did it, stand on it with my foot. It doesn't spring out like you think it would (I've tested this on 6 cars already). Below you will see a video of me removing the 17mm nut and the strut coming apart. I was probably only applying 70 lbs. of pressure to the spring with my foot, so it's much more effective if you sit on the spring and remove the nut. Even though I have deemed it safe, you should have the spring aiming away from anything that it might cause damage to just in case it's under a little more pressure. And if you have access to a spring compressor, then don't be a man. Use it.
robbie374
Jul 7, 2015 02:56 AM
7thgensurvivor
Jul 5, 2015 12:17 PM
Youshoe
May 22, 2015 09:36 PM
pdxbiker
Nov 7, 2001 10:06 PM
