Will it fit if I modify my axels?
I want to change all my brakes to disk.
I understand we can do the SI convertion 4 lug nuts.
Or the RSX convertion 5 lug nuts.
Although I will not get the stock disk (bigger aftermarket)
I'll have to change some parts to make this any of this two choices work on my 01 civic.
How will this affect the fitting of the shock ,coilovers, springs, camber kits courrently avilable for our cars?
ThE FaMiLy SeDaN
si ones all ud need is rears and everything works fine still
RSX the front axles dont fit in right... but the rears work fine..
hector.. id just do si rears... unless u wanna buy some pimp wheels from me 5 lug and do it up baller style..
But I'm concern about the fitting on the 5 lugs.
I think the SI convertion will be good after that getting aftermarket bigger disk and calipers.
I want a good shock spring combo too.
ThE FaMiLy SeDaN
hector if u want wilwood brakes i can give u a discount of 30% off... 4 piston fronts, 2 peice rotors and for rear 2 piston calipers and 2 peice rotors...
norm like 1400 i can do like 1k on front caliper/rotor setup
rayman009
Sep 12, 2015 08:30 PM
Biggunschad
Sep 11, 2015 04:06 PM
Ultra Havoc
Sep 9, 2015 10:58 PM
