Need Help with GC Coilovers...
Old Oct 26, 2004
Ballatician's Avatar
Ballatician has a spectacular aura aboutBallatician has a spectacular aura about
Today, I had some ground controls coilovers installed but for some reason my front is still stock height and the back is tucking. The shop told me that I will need to get aftermarket struts for the front because the front adjustable part on the coilovers want go over the stock strut. Anybody else have this problem?
Old Oct 26, 2004
ZdS03Civic's Avatar
ZdS03Civic is an unknown quantity at this point
The shop installed them wrong. On the front struts, there is a brass cap. You are supposed to pop them off, then the sleeves will slide over the strut assembly.
Old Oct 26, 2004
Ok I seen the brass cap your talking about but inside the sleeves there is a little ring of metal not allowing us to slide it down the strut.
Old Oct 26, 2004
ZdS03Civic's Avatar
Is the metal ring placed in the sleeve loosely or is it fabricated in with the metal?
Old Oct 26, 2004
It is fabricated with the metal.
Old Oct 26, 2004
ZdS03Civic's Avatar
You have the wrong sleeves. Call Ground Control, they will get you the correct sleeves.
Ground Control Customer Service (1-530-677-8600)
Old Oct 26, 2004
Yeah it is on the inside of the two front sleeves. I'm only able to slide the sleeve down about .5 - 1 inches on the struts.
Old Oct 26, 2004
ZdS03Civic's Avatar
See my previous post.
Old Oct 26, 2004
Ok, thanks...
spiffyweb
Mar 15, 2012 07:45 PM
TRIZ
Mar 4, 2012 11:59 AM
Flako
16
Nov 23, 2011 04:51 PM
gsniper666
Jul 22, 2007 11:31 PM
AznSaint
Jul 16, 2003 10:56 PM
