help please!!
help please!!
hi guys. i have a 2001 coupe and i want to barly tuck the tires and i plan on getting 17's in the future. i also want springs instead of coilovers. what would be a good set up for me and would i need to get shocks?
wtf? my sportlines tuck a good 1-2cm in the back and are 2finger gap AT MOST in the front and thats a 1.5" drop there are springs that will do a 2" drop, that should be plenty..
any lowering you should get aftermarket shocks, I used Tokico w/ my Eibachs, the instructions say not to lower more than 1.5" so you might want to try Koni instead they might be better suiter for going lower, just read the reviews and product info.. there are tons of springs that go lower than 1.5" I think 2" is enough to tuck.. wouldnt tuck much, but if u just want negative wheel gap, I think 2" is ok.
Goldline = 2" drop
Neuspeed Race = 2.25" Front & 2" Rear
Skunk2 approx 2-2.5
^^^ thats just from product descriptions under reviews.. check it out to make sure thats correct info, but it appears u have 3 choices from just whats listed, there might even be some others that didnt get listed..
Skunk2 approx 2-2.5
problem is u wont know for sure until u do it.. check the link above to see pics of drops..
with 17s ur rims are bigger tires are smaller, so u'd tuck the same amount as stock
my ride is harsh enough w/ a 1.5 drop, 2" drop would look really good, but probably be a rough ride..
Originally Posted by shmik1
fyi.. I have heavy subs in the back so it prolly wouldnt normally tuck..
Originally Posted by ohnoitssoysauce
should i get the rims or the springs first?
