What springs will support my stereo?
Old Oct 18, 2004
Rufus's Avatar
OK everyone I have an 03 Coupe and have a fully fiberglassed trunk. I had Eibach Sportlines on the car, but the stereo made the back sag too much. I've heard of using sedan springs for a higher load rate, but I'd like to see if anyone has tried it yet and get some feedback. The car is back on stock springs now and still sags a little. So now I need to sell these Eibachs and buy something new.
Old Oct 18, 2004
robbclark1's Avatar
Retired suspension supermod.
it is not the springs, it is the shocks. get new shocks and maybe some springs with higher spring rates. Just getting higher spring rates won't do much. There aren't any springs that have higher spring rates than sportlines. Most springs will only be at most 35% stiffer than stock. You can get custom spring rates for many companies or get full coilovers.
Old Oct 18, 2004
Rufus's Avatar
So is the sedan myth busted?
Old Oct 18, 2004
robbclark1's Avatar
what myth?
Old Oct 18, 2004
djmota's Avatar
Get the sedan version of the sportlines, This should help a bit with your sagging problem. It may not solve it depending on how much wieght you have back there, but it will help.
Old Oct 19, 2004
dtexan's Avatar
dtexan is an unknown quantity at this point
I would suggest coilovers then if you add more weight you can just raise them up and keep the car even
Old Oct 19, 2004
Rufus's Avatar
Coilovers (sleeved anyway) seem way too harsh. I liked the Eibachs but the sagginging sucked. The ride WAS nice though.
Old Oct 19, 2004
shmik1's Avatar
I have sportlines and my back does sag a little, but o well.. my subs weigh a ton..
Old Oct 19, 2004
HShadow's Avatar
Yup, it is the shocks. The spring will help but in the long run you will have to replace the shocks and springs because the shocks will give out and too much weight on the springs over time will damage them. You might as well solve the problem now instead of waiting till this happens. I had the same problem with my sedan. I had a full custom trunk that weighed a ton. Over time my back shocks gave out and forced me to go another route. I got bags because I had my system was built with all wood, but fiberglass wont weigh as much so you should be safe with a true coilover setup. Maybe look into Teins or something similar. I just reciently changed to Teins SS and love the ride, handling, and its ability to hold up the weight.
Old Oct 21, 2004
dtexan's Avatar
I previously had progress springs, and when I had a sub and box in the back around 75lbs the back end would sag a little. I switched to a lighter sub setup and it made a world of difference not only in the ride height, but also in the accleration of the car
Old Oct 21, 2004
Rufus's Avatar
Changing the box isn't an option though. It's fiberglassed into the tire well. 4.2 cuft for 2 Diamond TDX 10's.
Old Oct 21, 2004
FALKEN's Avatar
Civicforums Junkie
if your staying with the spring set-up...
i would suggest going with the sedan versions (like the Neuspeed or GoldLine)
Old Oct 21, 2004
shifthis's Avatar
shifthis will become famous soon enoughshifthis will become famous soon enough
I have the tokico blues and my backend sags because of my stereo. maybe, but maybe because I have coupe springs in a sedan. I dont think the shocks are the answer I think it is the springs.
Old Nov 19, 2004
ty.barrack's Avatar
ty.barrack is an unknown quantity at this point
Just airbag the whole car, you can adjust ride hight at front for more rake, or even corner to corner when you park you can drop it on the floor.
Old Nov 19, 2004
D17thgen's Avatar
D17thgen has a spectacular aura aboutD17thgen has a spectacular aura aboutD17thgen has a spectacular aura about
eibach sportines are known to sag your rear for some owners.
have you tried taking out your system of your trunk and see if the rear still sags? new springs wont do as much as if you were to replace some better shocks. your better off investing into shocks. if you wait til you blow them out, then your lose OEM shocks and start looking into new ones.
SammySC
121
Apr 7, 2017 07:43 PM
skeener51
Oct 1, 2015 05:56 PM
Bruce2
Sep 27, 2015 08:45 PM
260000milesgoal
Sep 25, 2015 07:41 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
