one inch drop
Old Oct 17, 2004
VashtheStampede's Avatar
VashtheStampede is an unknown quantity at this point
one inch drop
I want to put a one inch drop on my civic, but was told by one of the guys at the shop that I should also get new shocks. Will a one inch drop affect my camber and my stock struts and shochs? I had read that a drop over an inch and a half will start to mess things up.
Old Oct 17, 2004
robbclark1's Avatar
Retired suspension supermod.
Did you read the FAQ??? It has it ALL clearly laid out in there!! READ IT!!!
1) any drop will weaken your shocks
2) 1" or above probably won't be so bad
3) it is suggested to get a camber kit and shocks to save yourself from blowing shocks or ruining tires, but a 1" drop shouldn't be that bad. You decide. Everyone will tell you different things.
Old Oct 17, 2004
flotsamm's Avatar
Eibach's Pro kit is designed for work with stock shocks and struts I believe.. that would be your safest bet other then the FP kit from Honda. Someone please correct me if I'm wrong thx.
Old Oct 17, 2004
robbclark1's Avatar
so are the tein S-tech's, but that doesn't mean your shocks still won't get weak. I mean they get weak regardless of lowering, but lowering does it faster.
Old Oct 17, 2004
Mr.Modify's Avatar
Eibach and Tein S. are ones that will work with the stock shocks a little more but doesn't mean they won't get weak like Rob said. Camber kits aren't neccessary but it is recommend in the long run.
Old Oct 17, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Learn how to read FAQs.
beanhead
Sep 24, 2015 12:04 PM
bhollie
Sep 22, 2015 11:08 PM
TheRiddicles
Sep 21, 2015 01:28 AM
Juanb24
Sep 15, 2015 12:39 AM
yyyktk1
Sep 12, 2015 04:02 PM
