neuspeed X-Brace
Old Oct 14, 2004
auto84's Avatar
I R T3H 1338
auto84 will become famous soon enoughauto84 will become famous soon enough
neuspeed X-Brace
Well, I have searched and i havent really found the answer that im looking for. so here it goes, I carry neuspeed and i can get the x-brace for $135 and i want to know if its worth the money and the time for me to put it on. also will i have to remove it if i get the suspension teqniques sway bar set? thanks in advance - alex.
Old Oct 14, 2004
Vinh's Avatar
yes need remove
Old Oct 14, 2004
auto84's Avatar
I R T3H 1338
what?
Old Oct 15, 2004
robbclark1's Avatar
Retired suspension supermod.
If the st bar sits similar to stock then you should be fine. I thought the x brace was worth it but I took it off because it is illegal in ST and stock classes for autox.
Old Oct 18, 2004
auto84's Avatar
I R T3H 1338
ok, but will it get in the way of a sway bar? will i have to remove the x brace permanently ( would the x brace be replaced by sway bARs?)
Old Oct 18, 2004
robbclark1's Avatar
no. You should be able to run both at the same time, but don't quote me on that.
Old Oct 18, 2004
opto_isolator's Avatar
It is a worthy upgrade if you can stand the harshness of the ride. I have a complete suspension setup on my car (coilovers, front / rear strut bars / sway bars). When I had my x-brace on I could corner on a dime. I've since taken it off because it rattled with my magnaflow exhaust. But now that the turbo is back on I want to see about reinstalling it - it stiffens things up alot!
Old Oct 18, 2004
robbclark1's Avatar
It does stiffen things up, sometimes at the loss off oversteer. You might plow a little more with x brace, but it will be a lot stiffer.
Old Oct 18, 2004
auto84's Avatar
I R T3H 1338
I am just looking for a good handling street car that can do a little autocross at my friends lot where there are no rules... so go ahead and do it (also my rep said he's get it to me for $110 now!)
Old Oct 19, 2004
AceKicker's Avatar
AceKicker is an unknown quantity at this point
I would say get the tanabe Sub-frame brace instead. I know that grey has it and mine is sitting at my house. It looks like it would do alot better job with tightening up the front end If I were you I would go under greys DIY and read up on his one about the Tanabe sub frame brace and check it out compared to the x-brace. you will see waht I mean.
Old Oct 19, 2004
auto84's Avatar
I R T3H 1338
ok thanks acekicker
Old Oct 20, 2004
AceKicker's Avatar
Hey it is my pleasure to give out some advice or my opinion but what do you think what is your opinion now?
Old Oct 20, 2004
robbclark1's Avatar
Just FYI, grey's tanabe cracked. I never had a problem with my x brace...Just something to keep in mind.
Old Oct 20, 2004
AceKicker's Avatar
really wow i def didnt know that. how did he know it cracked and what cracked the welds or the actual bar?
Old Oct 20, 2004
robbclark1's Avatar
http://www.7thgencivic.com/forums/sh...hreadid=152681
It was his fault, but you have to recognize how low the bar sits compared to the x brace.
Old Oct 20, 2004
AceKicker's Avatar
Well really how much lower does the bar sit from the X-brace. taht would be some good info to put out. I will jstu be a little smarter the grey and not go onto the shoulder. lol.
Old Oct 23, 2004
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
damn for $110!! if it will fit an 02 4D get me one while yer at it
Old Oct 23, 2004
robbclark1's Avatar
yes it fits all 7thgens. google neuspeed x brace
Rogelio Rey
May 24, 2015 08:30 PM
brodie_rider
Apr 13, 2002 05:01 PM
ChEe12iO
Apr 2, 2002 08:49 PM
Civic2k2RacerX
Mar 31, 2002 01:26 PM
VanDizKo
Feb 17, 2002 05:19 PM
