$1000 for suspension. any suggestions
well im currently running on goldlines with everything else stock and my ride is
now im looking for something within the same drop. my drop was about 2" and well im looking to get my suspension set up correctly so i have a G to spend on suspension and well im looking for some advice on what to get. i dont know if i should keep the goldlines or get something better but all i have is a $1000. so please advise
now im looking for something within the same drop. my drop was about 2" and well im looking to get my suspension set up correctly so i have a G to spend on suspension and well im looking for some advice on what to get. i dont know if i should keep the goldlines or get something better but all i have is a $1000. so please advise Registered!!
Get some toyicko shocks($350) to go along with that. Rsx Sway bar($60). Neuspeed Strut bar ($100). That would be a pretty good combo and its cheaper than what you wanted to spend. And yes theres way more suspension parts but this should be pretty good setup.
And did you want to make your car handle on the streets or on the track as in AutoX.
haha. they should know what they're doing, otherwise they shouldn't pick up another wrench. they should see right away that the bolt is too big. common sense would be to drill it so it fits correct? that's the only mod for the tokicos as well as the B&G coilovers. i'm assuming that it's the same for the teins, but i haven't heard about it.
http://www.tein.com/ti/a22.html
That has all the specs you will need for Tein models for the 01+ Civic coupe and sedan.
I heard Koni's and Goldlines are a nice combo..
The cool thing about an aftermarket spring and aftermarket strut(Koni, Tokico, KYB) combo is that you can always try out different setups. If you dont care for that option then perhaps consider a nice coil over setup.
Definately go for full coilovers. Get those Teins and some Energy Suspensions urethane bushings. For about $125 front and rear, the bushings were the best money I spent on my suspension. Some people might say the ride is too rough but I don't think so.
maybe check these out
http://cgi.ebay.com/ebaymotors/ws/eB...923638318&rd=1
Dangerousjordan
Jul 28, 2015 08:24 AM
is it safe?
will most mechanics know what they are doing or will they look at me like
