winter driving
Old Sep 3, 2004
jus_sum_guy's Avatar
jus_sum_guy is an unknown quantity at this point
winter driving
I've got the Tein super street dampers. Since i don't have money for a winter beater yet, i'm gonna have to drive my car this winter. I'm gonna raise it all the way up and have a go at it. Will winter do anything to the suspension?? Also i was told i have to adjust the camber when i lower or raise my car, this true??
Thx!
Old Sep 3, 2004
MrWong's Avatar
Bushido
MrWong is an unknown quantity at this point
Just use cooper antisieze on the height adjustment areas to prevent rust and seizure. and rinse them off once a week in a wash bay or something.
I am in the same prediciment as you and that is what i am planning on doing.
If you have a camber kit you can adjust the camber when you lower/raise, it will help with premature tire wear
Old Sep 3, 2004
BrotherSound's Avatar
BrotherSound is an unknown quantity at this point
The Threads & Spring Seats wont Rust, I believe the Spring Seats Are Aluminum, and I believe the Threads Are Stainless Steel. The only Thing you need worry about is that green paint chipping Off, if & when that paint comes off then you'll start seeing rust. the rears tend to get more of a beating being so much closer to the ground. just rinse them off and spray some wd (or similar) on them once in a while, thats about all you can do.
Old Sep 3, 2004
Thx for the advice guys. But one thing, what do u mean by "seizure" exactly??
Old Sep 3, 2004
MrWong's Avatar
Bushido
Seizure means the salt and whatever junk they thow on the roads during winter will corode the metal causing the spring adjustment collars to lockup (ie you cannot raise or lower the ride height).
Even though parts are made of Aluminum and Stainless Steel, Tein of Japan and Tein of USA highly recommends that you lubricate the height adjustment areas during winter to prevent seizure from happening.
If you do not believe me, email them yourself and ask them the same question you asked above.
Lubing combined with rinsing them off in a wash bay once a week, will keep your suspension in tip top shape.
Mind you even during the summer I rinse them off once a week to get rid of the dirt road tar, and whatever else junk that is caught up in there.
Preventative maintence is the key, just like with other parts of your car.
Old Sep 3, 2004
Ohhhhh ok. Sooooo where can i get the lubricant?? lol. I know i'm dumb
Old Sep 4, 2004
MrWong's Avatar
Bushido
You can find it at Parts source, kinda expensive though $15 a jar.
Old Sep 4, 2004
blouisgod's Avatar
Life Begins > 6800rpms
ha, im not raising my b&gs. Im taking on winter down 3 inches
Old Sep 4, 2004
WannaBFast's Avatar
Prowlin' with a Purpose
well what you can do.. is put the stock struts back in... hehe
Old Sep 4, 2004
MrWong's Avatar
Bushido
^^ actually that is a good idea.
Old Sep 5, 2004
CrazyCakes's Avatar
CrazyCakes is an unknown quantity at this point
if want to get an alignment after the stocks go back on, and again next spring. i drove all last winter (in Michigan) lowered 2 1/2 inches, you'll be fine.
Xuhme
21
Aug 7, 2023 03:40 PM
sharp66
31
Jun 12, 2022 08:45 AM
juror
Jun 9, 2015 02:15 PM
bsmiley
Apr 27, 2015 01:27 PM
smmahan
Apr 15, 2015 08:17 PM
