Rear Camber on H&R Drop
Old Sep 2, 2004
joski's Avatar
MmmMMm.. I smell boost!
joski will become famous soon enough
Question Rear Camber on H&R Drop
I just installed H&R Sport springs (1.3-1.5" drop) a couple weeks ago.. My front has no camber and my rears have a slightly noticible amount. Let me know if this has been mentioned before, but I did a brief search based on "titles" and didn't find much.. I was looking in here and it mentions that an alignment could possible correct the small amount of camber I have. Anyone have any suggestions? Thanks in advance!
Old Sep 2, 2004
streetglower's Avatar
Well anytime you install lowering springs or mess with your suspension, you need to get an alignment. Thats why you are noticing the some negative camber in the rear. Now the shop might be able to get your alignment back within specs with out a camber kit, but you wont know untill you get it. I recommend you get one though so you wont wear your tires faster.
Old Sep 2, 2004
joski's Avatar
Oh, I was under the impression with such a subtle drop that you don't really need a camber kit but I'll get an alignment and see I guess.
Old Sep 2, 2004
robbclark1's Avatar
Retired suspension supermod.
Did you read the FAQ? It suggests a camber kit whenever you lower. Now you can try to get it to spec with the oem one, but an aftermarket one will give you more adjustability.
Old Sep 2, 2004
its better to have the camber kit though, liek robclark said, it gives you adjustablitly
Old Sep 2, 2004
joski's Avatar
Alight thanks alot guys! I'll get an alignment, see how it does, then buy a camber kit. Thanks for your help!
GolNat
Jan 12, 2021 09:06 PM
juror
Suspension DIY
Jul 30, 2019 03:28 AM
GotSiR
Jun 23, 2016 04:06 PM
JohnnyBxo
Nov 12, 2015 03:04 PM
Nalmonte
Jul 22, 2015 09:08 AM
