adjust camber yourself?
Old Aug 23, 2004
doubledeuce2k2's Avatar
i got an alignment done at stupid sears and they didn't touch the camber on the back wheels. my driver side one is fine (-.4), the passenger is like -1.9 degrees. and i had a camber kit on there.
should i do it myself? what should be done? i obviously only need to tweek it a little, want it at about 1 degree or at least no visual camber problem. by changing that, will it give me toe and caster changes too? want some good opinions before i crack open that can of worms
Old Aug 23, 2004
streetglower's Avatar
I say go back and tell them to adjust your rear camber since you have a camber kit on there.
Old Aug 24, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
If you have a gauge then you can DIY it. I do my own camber (plates in the front, UCAs in the back), then let the alignment shop deal with the toe. Caster is not adjustable, in the rear, camber changes might cause minor changes to the toe, but nothing significant or out of spec. If you paid for them to align all 4 wheels, then go back and make them do it.
Old Aug 24, 2004
Zzyzx's Avatar
Autocross Junky
Just remember, if you adjust camber you also alter your toe settings....
Old Aug 24, 2004
that's what i was worried about. the tech was telling me he was running out of room to adjust some of the settings with (i am dropped on RSX eibach pro with koni's)
my toe in the back is .04 on both sides right now. if i just oh so slightly change the camber (get it within -1.5 deg) should i be ok? i don't want to go back for another alignment...
Old Aug 24, 2004
Zzyzx's Avatar
Autocross Junky
If you are reducing camber, that should give you more Toe adjustment... so You should be fine....
I dont see how the tech couldn't get the toe to 0 on your car...
I have an 01 EX with Eibach sportlines (konis too) and I have -2.3 Deg on the rear (-2.5 on the front), I still have 0 toe....
Old Aug 24, 2004
ok now i have a new problem. i got my exhaust fixed and the tech there said the ball joints are shot on the driver side (the popping should have been a clue). i look through the tech notes from my alignment and they circled stuff about "perceptible wear". should they have told me about this before i got the alignment done? because i know bad ball joints mean the car can't hold an alignment. i want the car suspension right so i'll pay the money to get worn parts fixed, but i don't want to waste $60 on an extra alignment that would have been avoided if the ball joints were just replaced. do i have a grief here?
Old Aug 24, 2004
XxSoVeReiGNxX's Avatar
they'll tell him "we can only give you an alignment for the factory/oem settings"
there's no camber bolts on stock civics, so they won't touch it. That's the crap they threw at me. and I have a 1" drop too, so afterwards the steering wheel was even more crooked than when i brought it in. since i agreed to their statement hoping that my wheel would get straight hopefully, i could not get a refund afterwards.
I brought my car to a smaller Goodyear shop and they did it old turntable style, not problems, no drifting to the side while driving, no crooked steering wheel, etc. Don't trust the big stores/places.
Old Aug 24, 2004
what pisses me off is they always hand out coupons saying bring your lowered, raised and custom cars to us. then they f a stranger in the ***.
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
meicalnissyen
Suspension
Sep 24, 2015 09:28 PM
TheRiddicles
Sep 21, 2015 01:28 AM
