ground control falls
Old Aug 17, 2004
bb17199's Avatar
bb17199 is an unknown quantity at this point
my setup is GC and yellow konis, rear GC falls when i jack up the car, how do i fix this? searched, no such as "falls"
Old Aug 17, 2004
robbclark1's Avatar
Retired suspension supermod.
what do you mean falls? You mean falls off the rear perch??
Old Aug 17, 2004
bb17199's Avatar
fall from the top mount
Old Aug 17, 2004
Zzyzx's Avatar
Autocross Junky
Dont worry about it. Its just because the suspension has more travel then the spring has length.
Old Aug 17, 2004
bb17199's Avatar
if i raise the height of my car, it won't fall, anyone knows?
Old Aug 17, 2004
Mr.Modify's Avatar
never had that problem....try it.
Old Aug 17, 2004
gaugeof12's Avatar
gaugeof12 has a spectacular aura aboutgaugeof12 has a spectacular aura about
That should be correct. GC's are adjustable, so when you adjust them to a very low setting they are MUCH shorter than stock. When you raise the ride height the springs should then be able to expand enough to hit the perch and thus not be loose when the car is off the ground.
Old Aug 17, 2004
bb17199's Avatar
thx for help everyone, if that's normal, what should we do when oil change, rotate tires, guys do these jobs may not know this problem, coz if you don't hold it to the right spot when the car is touching the ground, GC may not fit properly, it's too danger
Old Aug 18, 2004
djmota's Avatar
Its not that bad, Mine only do that on the front. When you get ready to put your car back on the groun just make sure that the spacer parts are sitting nicely on the spring. simple and easy.
RSJ
Jul 23, 2015 11:29 PM
califcamper
Jul 21, 2015 10:34 PM
Fred65
Wheels and Tires
Jul 14, 2015 06:40 AM
