Strut Issue?
Old Aug 10, 2004
EssEss21's Avatar
EssEss21 is an unknown quantity at this point
Strut Issue?
Hey guys, i just lowered my car using koni yellow struts and eibach ground controls and the coilovers are basically set to the lowest setting. I am getting a camber kit for it tomarrow and also aligned, but i am being told that my struts are gunna be **** if i keep it that low? i only thought that was for stock struts? Is there anyone running like 1.75 or 2 or even coilovers where its all the way down and are havin any problems. Thanks.
BTW, heres a pic...
Old Aug 10, 2004
Mr.Modify's Avatar
gonna be ****? define that? being that you have Koni's and what not........
Old Aug 10, 2004
Zzyzx's Avatar
Autocross Junky
THe konis are built to work at any ride height. HOWEVER if you bottom them out you will destroy them. so, as long as you don't bottom out the shocks then you'll be fine.
Old Aug 10, 2004
beastiek2's Avatar
This cost me 1500 points
beastiek2 is an unknown quantity at this point
Ya might blow them ^^^as stated above(then every bump you hit will feel like a brick wall) you should be fine for right now in time deffinitly they would need to be replaced, which camber kit you going with ?
Old Aug 11, 2004
EssEss21's Avatar
this may sound dumb, but how do i know if im bottoming out the shocks or not?
in anyones opinion if i put the coilovers ALMOST all the way down then will i have problems and need to replace my struts?
and Mr Modify, im defining **** as the ride will be horrible and feel like crap and ill need to replace em.
I dont know what Camber kit im gettin, i think when i take my car to the my shop they are just gunna throw a kit on there.
Old Aug 11, 2004
GaryC17's Avatar
GaryC17 is an unknown quantity at this point
BTW, heres a pic...
The konis shouldn't blow so easily, or no one will buy those aftermarket springs which drop 2.0 inches or less. It will not make sense to design a spring that low anymore. As for the bottoming out, I have heard koni's can't take much of that... but if the spring rates are high enough, they shouldn't bottom out right? I got this feeling that large rims and low profile tires will destroy the shocks/ konis faster, as there is less absorption of the impact from the grounds by the tires. Therefore the shocks take all the beating. Can anyone clarify this ?
Old Aug 11, 2004
Zzyzx's Avatar
Autocross Junky
the simplest way is to attach a zip tie to the shock its self to measure how much suspension travel you are using...
Like such
adjust the zip tie so that it sits against the body of the shock, when you go drive the shock will move the zip tie to the highest compression point, and tell you if you need to raise the car up a bit or get stronger springs... (If the zip tie ends up at the top of the shaft then you are bottoming out the shock)
Old Aug 12, 2004
EssEss21's Avatar
wow, thanks!
Old Aug 12, 2004
jttegx's Avatar
OMNES AD UNUM
^^thats a very useful tool, good stuff
but i have a question, after placing the zip-tie, should i drive under the worse roads i know of or flat surfaces? go over speed bumps and dips too?
Old Aug 12, 2004
Zzyzx's Avatar
Autocross Junky
Drive it where ever for afew days...
Old Aug 12, 2004
GaryC17's Avatar
Zzyzx, The bumpstop will interfere with this procedure.
Old Aug 12, 2004
Zzyzx's Avatar
Autocross Junky
Its possible, but if hes hitting the bumpstops then he all ready needs raise the car up a bit or get higher spring rates...
Old Aug 12, 2004
pbfoot's Avatar
hmm...thats a good idea. im gonna try that on my next car.
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Nalmonte
Suspension
Jun 9, 2015 07:08 PM
beachglass
Jun 1, 2015 08:28 PM
