Softer ride
Softer ride
I'm new to this site and really like the "threads" so I'd thought I'd ask this question (no laughing please): I have an 02 Civc EX Coupe and it rides, I think, very hard on it's stock springs and struts. I am not a racer or modifier and want a "smoother" less ridgid ride. This is my 3rd Civic and I was surprised at it's ride qualities. My daughters 99 Civc EX has a much smoother and less jaring ride over normal streets etc...
Any thoughts on what I could replace the stock struts / springs with to "soften" the ride up?
Lar
Lar
now thats a new question i havent seen..... I'm not sure you'll be able to soften the ride that i know of. Heh, i thought mine was WAY soft with my stock springs
Autocross Junky
What PSI are your tires set at? and if you want a softer ride, you'll need 2 things. Softer springs and softer valved shocks.... the springs can be found, but I dont think there are any shocks out that have softer valving then stock.
Sofer ride
Thanks for the quick replies! Tires are at 31 F/28 R. I've tried taking them lower but not much change in ride quality.
I would be willing to do the springs. Suggestions on what kind and where to shop etc..? Do I need to know stock spring rate?
Lar
Lar
I would say get some eibach sportlines or eibach prokit springs. They will give you a drop though. Best bet would be the prokit, they only drop the car about 1 inch. Check any local race shop, they can get them for you. But I would try the internet. Alot cheaper. Here go to this link
http://robearracing.com/pd_eibach_prokit.cfm
robearracing is a great place to get online stuff for our car. Rob is a great guy. very good customer service and fast shipping.
Also I would keep the tire pressure at between 30-33 for the front and rear. Anything less would make your ride worse.
The older civics have a completely different suspension when compared to our 7th gen's, which is probably why ours ride "harsher" than the older civics.
Or at least that's what I'm lead to believe.
im not a big suspension person but i think better springs that fit your description and shocks to go with it will satisfy you.
we have many springs to choose from for our 7thgens. to find out which springs have the softest spring rate and hardest, gotta do a lot of searching for that
as for shocks, we have 2 out on the market. koni yellows and tokico blues. the konis have adjustable dampers i believe? but a price to pay for. tokico blues are a good set of shocks for daily driving. but not adjustable at all.
springs - $100-200
shocks - $300-500
here are couple sites to purchase goodies:
www.robearracing.com
www.importhorizon.com
www.dezod.com
www.streetlevelperformance.com
those sites should have good parts for your 7thgen.
welcome to the site
springs - $100-200
shocks - $300-500
www.dezod.com
welcome to the site
I would recommend the konis. I have them and love them. They make the ride alot firmer and alot better handling. Yes there are pricey, but just look around. I got mine brand new off ebay for $530 shipped. Plus the $160 I paid for the install. Only bad thing about them is the front are inserts, as were the tokicos are full replacements.
You could downsize the front swaybar from the 25.4mm to a 15.9mm from the 03' and 04' civics, that would give you a smoother ride over uneven bumps. The downside is this would give you more body roll. Aftermarket struts and springs are going to be stiffer and give you a firmer ride. Trade it in for a Camry?
Originally Posted by streetglower
thats what he is looking for, a better ride. Good shocks and springs will give you a better ride.
He said he wants a smoother ride, and to be not as harsh. He says he has stock springs and struts. Sounds like he wants a squishy ride, so he should look into the smaller swaybar and different tires, or a different car. The konis are valved higher than stock, how would they give him a squishier ride?
I got the vibe he wants squishy, and I would think the Konis couldn't give as squishy a ride as stocks. They're going to control the springs better, but initial bump should be stiffer than stock, resulting in a firmer ride. I don't have konis though, as you do, I can only guess according to how I tune mountain bike dampers.
The konis give me better handling. The ride is firm though, I go over speed bumps and stuff slow as hell as to not try and blow the suckers. But I have to say they are way better than stock.
Stock sucks, but it is soft. The real issue with the stock civic is the shocks, they wear out fast and don't have good performance...(good to me is BMW ride quality).
Also, I don't think replacing the springs is going to smooth out the ride.
I rode in a civic with B&G's, it had a one finger gap...
The ride was smooth, flat, and comfortable.. in general: much less body motion, and way better performance then stock. It was firmer, when you pull out of a driveway you know it's a performance suspension, but I thought the ride comfort was excellent.
Are you still having a hang-over after your test drive?
you ask me if there was any difference after running a cat-back exhaust and a header, you could probably test it on monday so you can judge for yourself.
Back From The Banned!
I would assume any type of aftermarket spring would make the car handle better via spring rate. I think the another solution though.... is air suspension.... but no one makes that for the Civic.
I Queef > You
How about those Teins? Those are a lot of money though... I wouldn't pay so much just to improve a softer ride. If my car was still stock I wouldn't be scared to blow my shocks b/c I could just go to Honda at get get it replaced with warranty. (mine is extended up to 100,00, but obviously not on my suspension anymore. Just on my stock engine I guess)
TheRiddicles
Sep 21, 2015 01:28 AM
BBrosario
Sep 17, 2015 07:51 PM
