Front lower tie bar...
Old Jul 15, 2004
Zzyzx's Avatar
Autocross Junky
Ok, 30 min wasted serching, so.. Any one know who makes or sells a FRONT Lower tie bar for our cars. And Dont bother posting about any of the Cross braces, because they are not legal for the class of racing I Do.
Thanks
Old Jul 15, 2004
robbclark1's Avatar
Retired suspension supermod.
Sorry man. As far as I know, there isn't one. Have boiler or you pops custom one up.
Old Jul 15, 2004
Boilermaker1's Avatar
Jap-Euro Fusion
Spoon makes the only legal one. Its just a straight bar.
My advice, fab one up.
Old Jul 15, 2004
Zzyzx's Avatar
Autocross Junky
So ony the much over hyped/priced spoon makes one eh? Probably runs in the $150+ range...
The problem with building one is that I can only do it at my dads shop, and I dont get down there but for a weekend every couple of months (They live in San Diego)
Old Jul 15, 2004
robbclark1's Avatar
Get to work bitches so you can sell me some custom parts
Old Jul 15, 2004
Zzyzx's Avatar
Autocross Junky
Robb.... You have the X brace right??? and didnt you say something about taking it off soon? It would be great if We could get some measurments off of it.
Old Jul 15, 2004
jnycash's Avatar
jnycash is an unknown quantity at this point
Ask Boiler, but I'm sure I could design one with Pro/E that couldn't be machined...
But seriously, if it's anything like the rear, I bet you could fab one up. Maybe if you came up with a design you could see if anyone else in the area has access to a machine shop.
Old Jul 15, 2004
Jap-Euro Fusion
Get me the dimensions and the diameter of the bolt it attaches to. I can rig something up.
Making a spoon knockoff is easy... their stuff isn't a marvel of engineering as I've discovered.
Old Jul 15, 2004
robbclark1's Avatar
Sorry Spencer, took it off and sold it. What points do you need the measurements for? There were 4 bolts attached to it. 2 when into the front on the control arm and 2 went into the subframe.
Old Jul 15, 2004
Zzyzx's Avatar
Autocross Junky
The rules require it to be attached to the Control arms...
17.8 G.
Strut bars are permitted with all types of suspension. Strut bars may be mounted only transversely across the car from upper right to upper left suspension mounting point and from lower right to lower left suspension mounting point. No other configuration is permitted. Additional holes may be drilled for mounting bolts. Only bolt-on attachment is permitted.
Old Jul 15, 2004
InanimateCarbonRod's Avatar
InanimateCarbonRod will become famous soon enoughInanimateCarbonRod will become famous soon enough
I'm going to recommend against the Spoon bar. It hangs too low and is in front of the tires. Big time speedbump bait.
Old Jul 15, 2004
dj02's Avatar
im sure one of u guys can fab one up. spoon one goes for 149.00 at hondawerx. im sure you can find it cheaper somewere else.
Old Jul 15, 2004
robbclark1's Avatar
Yeah, the x brace doesn't brace to the chassis like a tie bar does. Completely different holes. You need the holes that are similar to the ones in the rear, correct?
Old Jul 15, 2004
Zzyzx's Avatar
Autocross Junky
It shouldnt stick out any more then the Neuspeed X brace.... they use 2 of the same mounting points.
I assume that this is the proper mount location??
Old Jul 15, 2004
Zzyzx's Avatar
Autocross Junky
Gotta love Pegasus Auto racing supplies when it comes to fabricating suspension parts...
http://www.pegasusautoracing.com/index.htm
Found some threaded tube ends...
http://www.pegasusautoracing.com/pdfs/119.pdf
and Tie rode ends..
http://www.pegasusautoracing.com/pdfs/117.pdf
Now where to pick up some decent tube stock,
The mice are working over time now.
Old Jul 16, 2004
robbclark1's Avatar
Is that the front control arm mount?
Old Jul 16, 2004
Zzyzx's Avatar
Autocross Junky
Ya, the photo is from when I changed bushings.
The only problem I forsee is that the bolt that I need is Recessed a bit, so It wont be a direct bolt on, but rather a bracket will need to be made.
Old Jul 16, 2004
robbclark1's Avatar
K. I got some measurements. From the middle of the bolts it is 87.5cm across and you will have to recess it about 2cm.
hans.pcguy
Jul 12, 2015 12:19 PM
beachglass
May 22, 2015 09:59 PM
El_Spic
Apr 23, 2015 03:14 PM
JDQuikCivic
Dec 4, 2001 04:22 PM
BiGbRoWn
Bolt-on Engine Performance
Nov 21, 2001 06:17 PM
