need help ASAP
Old Jul 8, 2004
CrazyCakes's Avatar
CrazyCakes is an unknown quantity at this point
need help ASAP
I'm installing new suspension and i can't find the torque specs for our cars.
i know the strut tops are 33 front and 40 rear, but what are the bottoms and the tie rob end bolt?????
Old Jul 8, 2004
robbclark1's Avatar
Retired suspension supermod.
Front nuts and bolts that hold shock assembly to brake assembly(2 on each side):
116ft lbs. (includes oem replacement bolts)
Front end links:
29ft lbs
Front bolts that hold the bracket and bushings on front sway bar:
29ft lbs
Front nut that secures tie rod to shock assembly:
32ft lbs
Front and rear shock tower nut in center (on top of shock)
33ft lbs
Front three shock tower nuts (on top of shock around center bolt)
33ft lbs
Front brake hose and wheel sensor harness bracket bolts:
10mm one: 7.2ft lbs
12mm one: 16ft lbs
Rear bolts to rear upper arm or camber kit (all three):
43ft lbs
Rear nuts on end links:
top: 28ft lbs
bottom: 29ft lbs
Rear bolt that holds brackets and bushings on rear sway:
16ft lbs
Rear bolt that holds bottom of rear shock:
45ft lbs
Rear two shock tower nuts:
43ft lbs
Old Jul 8, 2004
flotsamm's Avatar
Rob you missed the torque spec for the pinch bolts.. I think theyre like 70 ft lbs or sumptin
Old Jul 9, 2004
CrazyCakes's Avatar
thanks guys i just snuged them all so i will torque them up.
Old Jul 9, 2004
robbclark1's Avatar
Eh I just copied from what was posted before. If I missed it, go find it fool!
