Koni problem!
Old Jul 8, 2004
1hOtSiLvErCiViC's Avatar
1hOtSiLvErCiViC is an unknown quantity at this point
Koni problem!
well i have koni yellows ionstalled with my ground control coilovers and i still bottom out...i have no idea what could be going wrong....thinkin maybe bumpstops were not put back on...what else could it be?...thanx for the help.....asap
Old Jul 8, 2004
flotsamm's Avatar
How low if your car? You should be able to see the bumpstop/dustcover on the front struts, but the rears are covered. Are you sure that they were trimmed down? I removed about an inch off of each when I installed my Eibahc Sportline springs.
Old Jul 8, 2004
Zzyzx's Avatar
Autocross Junky
If you are bottoming out....
The car is too low for the Spring rate on the car.
So, Either raise the car a bit or contact Ground Control and get stiffer springs
Just to note, your bottoming out problem has nothing to do with your konis, and every thing to do with your springs.
Old Jul 8, 2004
dirtySAMURAI's Avatar
I log in from time to time
My koni's are bent in the rear...
Old Jul 8, 2004
flotsamm's Avatar
Bent? You mean their shifting off of the rubber bushing? This is a problem with some earlier versions but should be corrected by now. I'd call Koni up.
Old Jul 8, 2004
No, it's just bent. My rear driver side koni is crooked.
Old Jul 8, 2004
Zzyzx's Avatar
Autocross Junky
what happened?
Old Jul 9, 2004
hit a pothole at 80mph, and the result == krooked koni
Old Jul 9, 2004
Zzyzx's Avatar
Autocross Junky
THat would do it... Ouch.
Old Jul 9, 2004
dj02's Avatar
wow! i want to see a pic of this. ride in the rear must feel like ****.
Old Jul 10, 2004
ride doesn't feel that bad. it just sounds horrible.
cukaracha
Jun 7, 2015 03:32 PM
Rogelio Rey
May 24, 2015 08:30 PM
cukaracha
May 16, 2015 07:36 PM
SneakerPimp
Dec 7, 2001 07:09 PM
